Audi A4, A4 Avant and A4 allroad quattro
Farbe: Gletscherweiss
Ingolstadt – The Audi A4 is a winner in the mid-size class. In top form both in terms of looks and technology, it stands out with its sporty, yet balanced character.
Body and interior
High- and ultra high-strength steels make the body of the Audi A4 stiff, lightweight and safe. The trunk has a capacity of 480 liters (16.95 cu ft). Capacity with the rear seatbacks folded down (a standard feature in the quattro versions) is 962 liters (33.97 cu ft).
The interior of the Audi A4 features all of the classic strengths of the brand – uncompromising workmanship, finely coordinated colors and materials, and logical, intuitive controls. Audi offers the luxurious climate-controlled comfort seats for the driver and front-seat passenger. Small fans provide three-speed ventilation to the seat cushion and back.
Powertrain
The engine lineup of the A4 is particularly broad, featuring 13 forced-induction engines with direct fuel injection. The top engine in the A4 models is a supercharged V6 – the 3.0 TFSI with 200 kW (272 hp).
Among the gasoline engines, the 1.8 TFSI with 125 kW (170 hp) stands out for its particularly high efficiency, consuming on average just 5.7 liters of fuel per 100 kilometers (41.27 US mpg). This four-cylinder unit features sophisticated solutions in a number of areas: the control of the valves and their lift, the thermal management concept, the injection system, the turbocharger and the integration of the exhaust manifold into the cylinder head.
The 2.0 TDI with 100 kW (136 hp) is the most efficient model in the A4 lineup. Its four-cylinder diesel consumes just 4.3 liters of fuel per 100 kilometers (54.70 US mpg) on average, a CO2 equivalent of just 112 grams per kilometer (180.25 g/mile). Audi also has two particularly environmentally friendly engines in the lineup. A sophisticated exhaust treatment system in the 3.0 TDI clean diesel quattro reduces NOx in the exhaust to the level of the future Euro 6 standard. The 2.0 TFSI flexible fuel is also designed for operation on bioethanol E 85.
Engine lineup:
  • 1.8 TFSI with 88 kW (120 hp)
  • 1.8 TFSI and 1.8 TFSI quattro with 125 kW (170 hp)
  • 2.0 TFSI flexible fuel and 2.0 TFSI flexible fuel quattro with 132 kW (180 hp)
  • 2.0 TFSI and 2.0 TFSI quattro with 165 kW (225 hp)
  • 3.0 TFSI quattro with 200 kW (272 hp)
  • 2.0 TDI with 88 kW (120 hp)
  • 2.0 TDI with 100 kW (136 hp)
  • 2.0 TDI and 2.0 TDI quattro with 110 kW (150 hp)
  • 2.0 TDI with 120 kW (163 hp)
  • 2.0 TDI and 2.0 TDI quattro with 130 kW (177 hp)
  • 3.0 TDI with 150 kW (204 hp)
  • 3.0 TDI quattro with 180 kW (245 hp)
  • 3.0 TDI clean diesel quattro with 180 kW (245 hp)
Three different transmissions are available for the A4: a six-speed manual with shift indicator, the continuously variable multitronic and the seven-speed dual-clutch S tronic. quattro permanent all-wheel drive with torque vectoring is available starting with the 2.0 TDI with 110 kW (150 hp) and is standard with the most powerful TFSI and TDI engines. The latter two can also be equipped with the sport differential, which actively distributes the power between the rear wheels.
Chassis
The chassis of the Audi A4 is made largely of aluminum and is very technically sophisticated. The front axle is a five-link construction; with a trapezoidal-link axle at the rear. The electromechanical power steering is sensitive and highly efficient. Audi also offers the optional Audi drive select driving dynamics system with efficiency mode.
Audi drive select can be paired with other technologies such as the sport differential, adaptive damper control and dynamic steering; the latter’s superposition gear can vary the steering ratio. ESC with electronic limited slip differential is standard in all A4 models with front-wheel drive. Using slight braking interventions at the front inside wheel, the system makes handling more neutral and ensures high grip when exiting the curve.
Assistance and infotainment systems
Audi offers a wide range of assistance systems for the A4 model series. The radar-based adaptive cruise control (ACC) maintains a constant interval between the car and the vehicle ahead at all times. At speeds below 30 km/h (18.64 mph), the system initiates emergency braking in the event of an impending rear-end collision. Audi active lane assist helps the driver remain in their lane, and Audi side assist monitors the blind spot and the area behind the A4. The driver information system with rest recommendation is standard in nearly every model.
There is also a wide selection in the areas of communication and infotainment. The versatile MMI navigation plus system can be combined with the Bluetooth car phone online, which connects the A4 to the Internet and brings the tailored Audi connect services on board. Another highlight is the sound system from Bang & Olufsen.
Audi A4 Avant
The Audi A4 Avant combines all the strengths of the model family with the most beautiful station wagon design in its class and outstanding practicality in everyday and recreational use. Its luggage compartment holds between 490 and 1,430 liters (17.30 and 50.50 cu ft).
Roof rails and a reversible cargo floor are standard; a load-through hatch with a ski and snowboard bag is available as an option. Upon request, Audi also offers the rear hatch with an electromechanical drive and additional practical features.
The same engine and transmission combinations are used in the Audi A4 Avant as in the sedan. Among the lineup’s highlights are the highly efficient 1.8 TFSI with 125 kW (170 hp), the powerful 3.0 TFSI, the multitronic, the S tronic, quattro all-wheel drive for models with the more powerful engines and the sport differential (for the 3.0 TFSI and 3.0 TDI). All engines come standard with a start-stop-system.
Engine lineup:
The driver assistance systems, infotainment and Audi connect put the Avant at the head of the field. The same applies to the sportily balanced aluminum chassis, which can be combined with the optional dynamic steering and damper control.
Audi A4 allroad quattro
With its permanent all-wheel drive, the Audi A4 allroad quattro is equally at home both on and off the road. It is somewhat larger, particularly in height, than the A4 Avant on which it is based. It offers 180 millimeters (7.09 in) of ground clearance.
Distinctive design details such as the stainless-steel underbody protection, the single-frame grille with vertical chrome bars and the range of wheels underscore its strong character. Its luggage compartment also holds from 490 to 1,430 liters (17.30 and 50.50 cu ft).
The engine lineup for the A4 allroad quattro is more streamlined than that for its sister models. quattro permanent all-wheel drive with torque vectoring is standard, with either the six-speed manual or the seven-speed S tronic delivering the power to the wheels.
Engine lineup:
  • 2.0 TFSI quattro with 165 kW (225 hp)
  • 2.0 TDI quattro with 110 kW (150 hp)
  • 2.0 TDI quattro with 130 kW (177 hp)
Comments ()
