March 21, 2013
Source: AWE Tuning
Willow Grove, PA -
AWE Tuning is proud to release the Stage 2 Performance Pulley Kit for 3.0T powered 2010 – 2012 Audi S4 and S5 models.
The AWE Tuning 3.0T Performance Pulley, coupled with special G.I.A.C. Stage 2 Performance Software was designed specifically to increase horsepower through increased boost pressure, without sacrificing reliability.
Through use of the smaller-than-stock AWE Tuning 3.0T Performance Pulley, the kit spins the 3.0Ts supercharger faster, creating more boost pressure while staying within the tested parameters of the unit. This increased boost pressure is used in conjunction with G.I.A.C. Stage 2 Performance Software to maximize the potential of the stock Eaton supercharger once coupled with the AWE Tuning 3.0T Performance Pulley.
The stock Audi ECU software directs a valve inside the supercharger to open, then waste (or “bleed off”) additional boost pressure. When the AWE Tuning 3.0T Performance Pulley is added, even more boost is created, as is the potential for even more bleed off. In steps G.I.A.C. Stage 2 Performance Software… preventing bleed off from happening by safely keeping the bypass valve closed, then optimizing ignition timing and air fuel ratios.
Highlights of the kit include:
- 488 crank horsepower on race fuel, 430 crank tq on race fuel
- Electrocoated black for factory appearance
- Precision ground for optimal fit on the supercharger snub
- Exclusive AWE Tuning 3.0T Pulley Removal Tool also available
- Developed in house at AWE Tuning and G.I.A.C.
- Mustang Dyno calibrated and tested
- Track tested at New Jersey Motorsports Park
- Limited lifetime warranty
“This release is the direct product of hours of dedication and obsessing over each small detail to bring to market a product that not only greatly increases the power output of the 3.0T, but also maintains perfect daily driving manners and reliability,” states AWE Tuning VP of Marketing, Jesse Kramer.
The Performance Pulley Suite will be offered as follows:
- AWE Tuning Stage 2 Performance Pulley Kit – Includes AWE Tuning 3.0T Performance Pulley (Pulley, Belt, Related Hardware, no tool) and G.I.A.C. Stage 2 Performance Software.
- AWE Tuning Stage 2 Upgrade – Includes AWE Tuning 3.0T Performance Pulley (Pulley, Belt, Related Hardware, no tool) and G.I.A.C. Stage 2 Performance Software for those who already have G.I.A.C. 3.0T Stage 1 Performance Software.
- AWE Tuning 3.0T Pulley Removal Tool – Just the tool itself. Pulley and Software not included.
