2001 Audi A4 1.8 Turbo White Smoke From Exhaust
Hello guys, I have a problem with my 2001 Audi A4 1.8T... There is a lot of white smoke coming from my car when I'm driving and when I'm parked. I did both a compression test and a smoke test. They told me it can't be the turbo; the mechanic looked with a camera, it was dry. The engine is also running fine; my pistons are fine. I was told I needed to clean my CRANK CASE: the exact note on the bill says "R/R and clean oil filter housing, replace PCV valve and suction pump." My question is: would this solve the problem with the smoke from the exhaust?
[QUOTE=Miroslav98;24745149]Hello guys, I have a problem with my 2001 Audi A4 1.8T... There is a lot of white smoke coming from my car when I'm driving and when I'm parked. I did both a compression test and a smoke test. They told me it can't be the turbo; the mechanic looked with a camera, it was dry. The engine is also running fine; my pistons are fine. I was told I needed to clean my CRANK CASE: the exact note on the bill says "R/R and clean oil filter housing, replace PCV valve and suction pump." My question is: would this solve the problem with the smoke from the exhaust?[/QUOTE
hi I'm having the same issue with mine did you ever find out what this may be
thanks
david
thanks
david
JUSTA4 -Matt
07-08-2008 12:42 PM
