2001 audi a4 1.8t blown head gasket? - AudiWorld Forums
Old 03-11-2012, 08:37 PM   #1
Default 2001 audi a4 1.8t blown head gasket?
CAR RUNS AND SOUNDS PERFECT JUST A LOT OF SMOKE COMING FROM EXHAUST ITS MORE OF A WHITE SMOKE KINDA LIKE STEAM BUT IT LEAVES THE EXHAUST OILY. THE ENGINE SOUNDS PERFECT NO DINGS OR WEIRD NOISES RUNS SMOOTH LIKE ALWAYS I DONT KNOW WHAT IS WRONG I TOOK IT TO A MECHANIC AND THEY TOLD ME IT MITE BE A RING ON THE PISTON OR THE TURBO OR A BLOWN HEAD GASKET WHAT DO YOU GUYS THINK? WOULD I HAVE TO REPLACE THE HEAD TOO? CAN I DO ANYTHING SO IT STOPS SMOKING SO MUCH? I HAVENT MOVED THE CAR SINCE THIS HAPPENED TO MEJUST ONCE TO THE MECHANIC I NEED HELP
silver01a4 is offline   Reply With Quote
Old 03-13-2012, 06:50 PM   #2
Prospeeder's Avatar
your turbo failed.
Prospeeder is offline   Reply With Quote
Old 03-13-2012, 07:02 PM   #3
ezveedub's Avatar
Like Prospeeder said, sounds like the turbo is shot. You can usually take out the O2 sensor and use a boroscope to view the turbine. Or pull off the inlet snorkel to the compressor housing and see the turbo wheel. It will usually be loose and oily when the turbo is blown.
ezveedub is offline   Reply With Quote
Old 04-02-2012, 06:59 PM   #4
I had the same issue, replaced the turbo, things seem to run fine for a while, but then started white smoking again and I have massive amounts of coolant in the engine oil that I can't seem to figure out where its coming from and my compression numbers are good..well, maybe not great, but here they are...would this indicate a blown HG?
Cylinder 1: 180 psi
Cylinder 2: 155 psi
Cylinder 3: 155 psi
Cylinder 4: 180 psi
LDub is offline   Reply With Quote
Old 04-05-2012, 05:58 PM   #5
Prospeeder's Avatar
yes. If you can imagine, the head warps from the middle, so being the middle 2 are lower, indicates that yes it warped the head or blew the gasket. Really nothing else except the oil cooler is going to put coolant in the oil. But if its actually burning it. and its not the turbo. yea head
Thread Thread Starter Forum Replies Last Post
Help with 2005 Audi A6-3.2L quattro BKH bballfreak A6 / S6 (C6 Platform) Discussion 4 10-12-2015 06:14 PM
2001 Audi tt runs, turned it off, now turns over but dies immediately? help plz vansoffyomama TT (Mk1) Discussion 2 09-28-2015 05:38 PM
Engine Swap?? CobraJones A6 / S6 (C5 Platform) Discussion 3 09-28-2015 08:57 AM
Audi A6 2001 A6 2.7T 6MT Melange 70,891 ScottCNelson Vehicles For Sale 0 09-27-2015 03:41 PM
Any link to 2003 A4 1.8T option codes ? mxp A4 (B6 Platform) Discussion 2 09-26-2015 11:15 AM
Tags
02, 18, 18t, 2001, 2003, a4, audi, blown, check, gasket, head, headgasket, how, replace, symptoms
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
