A4 1.8T B6 P301 & P0507 CODE
Hello I have a audi A4 1.8T B6 2005. the other day I went to the bank and after I was done thought there drive thru the car didnt want to go forward on D.
So I have press the gas harder several times to be able to get out from the drive thru and trying to find the nearest parking spot to find the problem, I notice the car was able to go in reverse but it was having hard time to go forward, it was jerking really hard when I press the gas pedal. I left the car there and came back the next day and I was be able to drive the car to home for 7 miles until the problem came back but I made it to home. I bought a VAG COM HEX and VCDS
and I scan it myself and found faulty codes.
I am trying to do the repair myself but Im not sure yet what parts could be the problem,I have been reading a lot to different forums but still confused, I hope some one could see my log data below and help me to go the right direction to fix this issue since stealer ship would take all my savings.
also I notice my battery reading was 11.695V I don't know if it could help?
Also my engine MIL light is on.
I would appreciate all the feedbacks Thanks.
Thursday,16,February,2017,22:12:39:64536
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.3.1
Data version: 20161010 DS267.0
Ross-Tech: Home
Mileage: 242500km-150682miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 BC HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0020
Revision: 00000000 Serial number: AUZ6Z0D0372849
Coding: 0016581
Shop #: WSC 06335 000 00000
VCID: 72EA59D96E5339D2BA-50AE
2 Faults Found:
19497 - Powertrain Databus
P3041 - 004 - Implausible Engine Temp. Message from Inst. Panel
16891 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent - MIL ON
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1424
Coding: 00000
Shop #: WSC 06335
VCID: 60CE2391E0BFBB42DC-50AE
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00231
Shop #: WSC 05140
VCID: 3662A5C912BB65F256-5090
WAUJC68E15A118653 AUZ6Z0D0372849
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to Plus
Ross-Tech: Home
Coding: 0016581
2 Faults Found:
Coding: 00000
Shop #: WSC 06335
1 Fault Found:
Coding: 00231
Shop #: WSC 05140
1 Fault Found:
Hola amigo. El voltaje de batería es bajo, controle el estado o cámbiela si es vieja. Cambie la válvula de control de venteo de gases de cárter que se encuentra en la manguera del respiradero, se rompe la membrana interior y desestabiliza el ralenti. Espero le sirva la información suministrada.
PD: se podría aportar mas información con el código de motor....
