A4 B5 1.8t Quattro losing lots of coolant
Hi all Audi fans, i am hoping to get some help here. So here is my problem - i am losing lots of coolant on my Audi while pushing it 3.5+rpm's. While driving it under 3.5rpm's its not losing coolant at all, drives like it should, but after pushing it hard soon coolant light start flashing and i have to fill it up again. Looked all over the engine bay for any leaks - none, drove it to local garage and had inspection on it - they had found nothing too. I don't know what to do now... Sometimes it looks like as if it's driving on a coolant, not petrol. Any ideas where to look for leak? Thanks in advance.
you should not be driving until you figure what the problem is.. (good) sounds like a crack in the coolant lines (bad) a crack in the cylinder head that reveals itself under pressure. need to find where the leak is coming from, maybe have someone gassing it up and inspect to see any leaks. good luck
I seem to be slowly losing coolant, and I notice a burning smell after driving...smells like coolant
nvr_follow
23
02-21-2008 06:12 PM
