Ross-tech Throttle angle reported
Old 02-13-2009, 07:35 AM
New Member
ffwjgross's Avatar
Default Ross-tech Throttle angle reported
I have a 1998 A4 1.8T ATQ, AEB engine with low power. (Also measuring no turbo boost.)
In ross-tech shareware, the engine module reports throttle angles up to 86 deg. and the Operational Status field never shows "Full" even at WOT.
The AT module does show 100% throttle.
Does the throttle body adapation compensate for this (so 86 deg = WOT) or do I need a new TB?
I swaped in a different used TB and it reads the about same values.
Old 02-13-2009, 07:56 AM
I was lost, now I'm found
myers1.8TQ's Avatar
Are you asking why you have low power/ no boost.
Old 02-13-2009, 10:25 AM
New Member
ffwjgross's Avatar
Default Re: Are you asking why you have low power/ no boost.
The goal is to get my power back
Wondering if I really need to replace the Throttle Body. I hope that would give me some of the power back.
I was maybe going to do another thread on the turbo after some more checking on my end.
I think I need to check to see if the turbo is turning. Diverter Valve diaphram leaks, but seals boost air closed. I feel no turbo anything at all, but I havn't driven the car in years. The wastegate is free. I'm showing a least a 1/4 inch vacuum at the intake manifold always.
Thx. Any Ideas?
Old 02-13-2009, 10:28 AM
New Member
ffwjgross's Avatar
Re: Ross-tech Throttle angle reported (for my post TB=Throttle Body)
Old 02-14-2009, 09:35 AM
k1.8t's Avatar
you need to start off by trying to adapt the throttle body to the ecu. i would clean the throttle body and install it with a NEW gasket. try re-adapting it to the ecu after you clean it. if it shows an error message in channel 4 after you cleaned it, odds are the throttle body is bad. as for the diverter valve, the condition of the DV can cause the car to overboost. in turn, the ecu will pull the timing out so far that it feels like you have no power. i strongly recommend pulling the turbo inlet pipe off and checking to make sure the compressor turns freely. good luck. i will answer any other questions you may have
Old 02-14-2009, 09:20 PM
New Member
ffwjgross's Avatar
Default carb cleaner spray? Thx, Ill try doing that
You mean clean the throttle body with carb. cleaner so it physically open up easier or clean the electronics inside?
Unfortunately (turbo $) I think I don't have an over boost problem, I never measured any boost ever... I will replace the diverter valve too once I check the turbo.
Thanks, I'll do what you suggested in a few days.
Old 02-15-2009, 02:45 PM
k1.8t's Avatar
Default Re: carb cleaner spray? Thx, Ill try doing that
yes carb cleaner. do not open the electrical portion. open the butterfly and clean the lines of carbon stuck around the butterfly when it is in the closed position. make sure it is completely spotless.
Old 02-16-2009, 07:29 PM
ScratchRob13's Avatar
That is drive by cable, you need to do a manual TB adjustment. its in the bentley manual.
TTwizted13StrtRcr
9
02-12-2008 04:18 PM
kadinsky
11-05-2007 07:13 PM
jjspierx
03-09-2006 05:41 PM
BQAD
07-07-2004 04:24 PM
Mike B
05-03-2000 04:17 PM
Quick Reply: Ross-tech Throttle angle reported
