Engine problems...any ideas???
I have an 01 a4 quatro 1.8t...65k miles. I was driving and the low oil pres. light came on/it also had a check engine light on. I stoped by auto zone and had them check fault codes. All that came up where,missfire on bank 1,2,4,@lean fuel. I drove it home/about 20 miles. And as I pulled in to my drive it died. Then an epc light came on and it wouldn't start. It turns over fine,all pullys move fine no odd sounds or anything. So I am sure its not locked up. I checked the oil pressiure and its ok. But it dosn't have any compression? I am not sure what the problem is or what to chek next?
Rare coincidence! Oil sludge for low oil pressue possible, level OK?....m
If there is no compression, sounds like you have a broken or skipped teeth on the timing belt and bent some valves. Besides broken belts, the belt tensionser assembly has a history for failing, letting the belt loosen and then skip teeth. Skipping belt teeth will cause the same damage as a broken belt.
3pt8 turbo
02-14-2007 11:44 AM
rushrx
09-21-2005 04:57 AM
kkii9
07-26-2005 02:42 PM
