Misfire on idle and no power
Old 04-30-2014, 06:22 AM
Minta18's Avatar
Default Misfire on idle and no power
Please help I have a 2004 1.8t a4 convertible which was running fine until a couple of days ago the ecs light came on all was still ok then it started to misfire and have no power I have changed the crank case breather valve which was faulty the disc was perished but no effect i have just ordered a pcv valve from audi hoping this will solve problem as the ecs light is now flashing !
Oh one more thing before the problem even started when I was sat stationery in traffic and engine was idling I could smell fumes now I can't ? Must be related somehow
Old 07-01-2014, 07:51 PM
Juanma32's Avatar
I had a problem like that before on my B6, try replacing your ignition coils and spark plugs. Also check if you have any burnt fuses.
If not, your ignition coil wiring harness may be burnt right next to the housing. Your dealership should have a repair kit available if not they can get it for you.
ELEVENS
Q5/SQ5 MKI (8R) Discussion
11-21-2014 05:29 PM
Toiffel
14
09-03-2008 06:07 PM
audibranquinho
Performance and Tuning
01-30-2006 05:01 PM
BLKonBLK
07-19-2005 01:49 PM
natex
11-15-2002 01:03 PM
Quick Reply: Misfire on idle and no power
