need help identifying hoses
Old 10-16-2014, 09:07 AM
Johnson812's Avatar
Default need help identifying hoses
I need help identifying a couple of hoses so I can replace them. They are on an 01 Audi a4 1.8t
Are these special or unique hoses that need to be ordered or can they be bought from say AutoZone?
Thank you
What is the hose all taped up called? For reference I believe it runs to the pcv
What is that connector called?
Old 10-23-2014, 01:20 PM
Johnson812's Avatar
95 views and no one can tell me if it is a generic hose or not? The other parts I needed just came in so hopefully it is.
Old 12-07-2014, 12:50 PM
smokeyjohn64's Avatar
the last one looks like a fuel pressure regulator, the underneath part you cannot see has 2 separate O-rings you cannot see
Old 12-07-2014, 03:16 PM
wmerchle's Avatar
Default PCV Hose!
That hose is for your PCV system. If its broken you will have a vacuum leak. Here is the part from ECS tuning.
Audi B6 A4 Quattro 1.8T Engine Emissions Hoses - 058133785B - Air Pump Hose - ES#277667
Old 12-07-2014, 03:19 PM
wmerchle's Avatar
That is not a fuel pressure regulator. That is the EGR (combi) Valve. There are two hose connections to that part. When that part fails it usually causes your secondary air pump to fail as well.
kevjo55
09-30-2015 08:02 AM
stigg
Audi allroad
09-28-2015 10:37 AM
Panelhead
09-28-2015 06:39 AM
felek_pl
3.0TFSI Engine Discussion
09-26-2015 08:59 PM
Bruce B
Q5/SQ5 MKI (8R) Discussion
09-25-2015 12:11 AM
Quick Reply: need help identifying hoses
