oil sensor lights on my audi a4 2001
How has the car been maintained? Regular oil changes?
If the oil pressure is not where it should be the light will go on. So, the oil pump could be gummed up or perhaps not working well enough. If that is ruled out, check the sensor itself. Lots of YouTube vids on this stuff.
Don't use the car until you sort this out or you could be looking at some serious $ ...
good luck!
good luck!
Did you ever find the issue with your car? In the picture it looks like the combination valve on back of engine has no vacuum hose attached. It is kind of hard to see, but thats what it looks like.
jeff sterling
08-25-2015 05:59 AM
egustaps
02-19-2009 09:59 PM
