Overheating Issue
Old 02-25-2015, 10:36 PM
candiipgh's Avatar
Default Overheating Issue
Just bought an 2004 A4; previous owner said they had drained and replaced the coolant. It's been overheating whenever I go uphill and the coolant level light comes on. When I stop or coast in neutral the temperature goes back down. If I'm driving on flat road I can drive forever without overheating; only when going uphill under the extra load it overheats. I've been topping off the coolant after each time I drive and it seems to be leaking little to none coolant. Help?
Old 03-01-2015, 05:49 PM
x19
x19's Avatar
Impeller on water pump is broken or radiator is clogged or? You will be able to check water temperature at the engine block, fitting of Radiator hose on e/block and radiator etc if you have an infrared thermometer. Good luck. x19
mike@fmc
Audi 100 / A6 (C4 Platform)
06-04-2011 08:54 AM
dassub
12
02-23-2007 03:41 AM
KillA6
2.7T V6 Discussion
12-14-2006 02:02 PM
KillA6
11-08-2006 06:23 AM
richmond5
01-24-2005 07:50 AM
Quick Reply: Overheating Issue
