1999 Audi A4 Transmission compatibility?
Old 01-09-2010, 07:14 AM
PepsiManKolt's Avatar
Default 1999 Audi A4 Transmission compatibility?
Hey,
Can someone tell me whether a transmission from a 1999 Audi A4 2.8L V6 would fit into a 2001 Audi A4 2.8L V6. What else would it fit in?
Thanks.
Old 01-09-2010, 08:52 AM
Answered by the dealer. The transmission codes are as follows-
1999: DRN
2001: FAS
So, for anyone that wants to know. They are not compatible.
Old 01-10-2010, 09:06 AM
Peter Badore's Avatar
The 99 and 01 auto transmissions will physically interchange but the tranmission speed sensors G182
use different mehods of reading the transmission speeds--99 is induction, 01 is hall effect. My friend's
BMW shop subcontracted an engine change on a 99 A6 Avant using a low miles 2001 2.8l ATQ engine and FAS 5 speed automatic transmission with bad results. The 2001 FAS had to come out and be replaced by the correct 99 EKX transmssion. The 2001 ATQ 2.8l V6 could be used in place the 2.8l AHA 99 engine with only a few changes.
Old 01-11-2010, 07:18 AM
Oh, Interesting.
Well actually what is happening is that I am parting out a 99 A4 and a guy with a 01 wants my tranny. What kind of "changes" would have to happen?
Old 01-14-2010, 11:03 AM
We tried lots of ways but to work the 2001 FAS ATX controller needs to talk to a 2001 engine controller for an 2.8l V6 ATQ engine. The 99 and 01 turbine speed sensors are not compatible and not interchangeable due to the redesign of the ATX turbine speed sensor to use a Hall effect sensor in place of the 99 model year induction sensors. My advice is to stay with the same year model components.
Old 06-12-2013, 10:26 AM
Always_Dumpin's Avatar
I just ran into this myself. Put '01 trans into my '99.. same symptoms - limp mode after a few seconds :/
My question is this: since I already have it installed, is there ANYTHING I can do to swap the 01's hall effect speed sensor over to the older g182 inductive sensor? I understand they have different mounting locations and therefore read off of different gears/equipment - I believe it was said in order to allow the hall sensor to work properly, you'd need the 01's tcm to communicate with an 01 ecm (which would be dbw, and require a LOT of modification to convert everything over to 01).. so my question is - what would it take to convert the transmission over to run the inductive type sensor? Since I have a dead trans I just pulled, I have any & all parts @my disposal IF the task is feasible.
Would it require only the bracket/mounting for the sensor, then splice it in/or change the internal harness.. Would changing out the whole valve-body/harness do any justice at all?.. or would it come down to changing out internal gears in the transmission from say magnetic to toothed?
-determined not to have to take on another transmission install!! (This is already my 2nd, first round replaced my junked trans with another junk unit -yay-) So if there's a way to make this work.. ugh, help??
Old 02-14-2016, 07:27 AM
Nestor Galindo G's Avatar
i got the same problem just put a 01 a6 2.8 q ''fas'' transmisssion into my 99 a6 2.8. same symptoms '' limp mode in 3rd gear'' any help.
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
Mesa512
20
07-07-2018 11:23 AM
Kerry G
05-18-2018 06:12 AM
Hours of Service
New Member Welcome Area
06-29-2017 05:07 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
Quick Reply: 1999 Audi A4 Transmission compatibility?
