2006 A6 major issues leak oil plugs and coils soaked with oil
The 2006 Audi A6 3.2L with 170,000 miles on it, was leaking oil i was adding lucas oil leak. A week ago it started roughly backfired and died, it did end up starting. I replaced the plugs and coils, when I did the driver side 3 coils and plugs where covered in oil the passenger side only one coil, the one in the rear was covered in oil. The car did overheat we stopped immedialty and the audi service center replaced both cooling pumps. From what I have researched my next step is to remove the valve cover and replace all the plug gaskets and cover gasket which has signs of leakage in several locations. The only concern is this happened so quickly.
SO as I see it there are several items I think are causing the issue. The oil is not like choclate milk and the coolant levels have not dropped, so I believe I can rule of the Head Gasket
-replace the valve gasket/coil gaskets
-replace the crank shaft half moon while I am in there (how do I do this with out take the entire bumper off???)
-Replace the O2 sensors while I will have easy access to them-IS THAT NEEDED?
-Replace the ECM (Is that needed? how easy is it?)
- Also is there any pump or sensor that regulates pressure in the valve area that could cause this issue?
- When I look at the valve cover there are two sensors on top of the valve cover do they play any role in what is going on?
- I do not have a computer to pull the codes so i do not know if there is a certain cylinder that would have any issues with the associated valves? How can I get a inexpensive one and would it help with any of the above.
- I can do all of the above work on without a problem when it comes to replacing the actual valve gaskets I have no idea no to proceed. I hope that I dont have to go there.
I apologize for the long post but I really need your help with this any suggestions of where to start and how do I identify other issues moving forward.
Agreed make.sure you get the set of gaskets that go around the sparkplug holes. Them are the ones leaking. Im pretty sure you buy two gaskets types one that goes on vavle cover and the other that goes around spark plugs. But never know
Edward Eustace
12-16-2017 11:52 AM
Edward Eustace
10-26-2015 03:14 PM
Edward Eustace
3.2 24v VR6
10-25-2015 03:59 PM
MCrouse
08-10-2011 09:54 PM
