2007 A4 2.0 TFSI Quattro, timing chain or belt? - AudiWorld Forums
Old 09-06-2011, 06:50 PM   #1
91c2wrencher's Avatar
Default 2007 A4 2.0 TFSI Quattro, timing chain or belt?
Recently had the A4 in for service (55K scheduled) plus a few other things. While talking with the service manager about the benefits of maybe just doing the timing belt now ( alittle overdue on the 55k serv.) he said he thought the car had a timing chain and not a belt, he'd have to check the engine serial number? The question is, when did the 2.0 turbo change over to a timing chain? how do I determine what it has?
91c2wrencher is offline   Reply With Quote
Old 09-09-2011, 02:33 PM   #2
Where are you located? For North America, the B7 model (2005.5-2008) 2.0T motor has a timing belt, with a recommended change interval of 110,000 mi / 175,000 km
The B8 models (2009->) with the 2.0T motor have the timing chain.
A4Audi4Fun is offline   Reply With Quote
Old 01-11-2012, 07:57 AM   #3
Just dropped my A4 off for the 75K service and asked about the Timing Belt replacement. I was told by two service writers that my car will not need the timing belt until 110K, which matches what you posted. However, the book (which I have stamped with every service) calls for a replacement of the timing belt on several engines, including the 2.0 TFSI which is what my car has, during this service. They continued to indicate that the 2.0 does not get a belt change at 75K. One of the service writers tried telling me that my car is not an FSI! So, is it 110K or 75K? The book calls for 75K but obviously the 110K number has some truth to it with you and the other service writer.... Just wondering if I should call them and keep pestering them. The car is a 2006 A4 2.0TFSI S-Line that we bought new. Everything has been done per the factory service guidelines and the book is up to date. Would hate to skip the T-belt based on unknown info! Thoughts? Thanks!
DGould04 is offline   Reply With Quote
Old 01-11-2012, 12:33 PM   #4
Prospeeder's Avatar
well 1.8T cars have had a timing belt interval of 105k and I have seen them consitently leak water pumps, break the impeller or break the belt and bend all the valves right around 80k. I would not wait till the milage interval. i would do it around 80-90k... it was already said, 2009+ chain. rest are belt
Prospeeder is offline   Reply With Quote
Old 01-12-2012, 05:17 PM   #5
imtimmy's Avatar
Just had timing belt replaced at almost 79k and water pump. I took the car in with check engine light on. Check engine light was for 3 possible codes. Throttle body which they replaced, engine was idling funny while still. Other 2 codes given are for intake manifold and motor, pvc. Audi just mailed out the extended warranty on these fixes to 10 years 120k When leaving repair shop just now, check engine light was still on. He ran the fault codes and it is for the problems that Audi is covering now.
I read on another post 6 years or 110k for timing belt. My A4 is just over 6 years and noting but problems since ownership at 38k miles. This is my 2nd Audi and will be my last.
imtimmy is offline   Reply With Quote
Old 01-13-2012, 07:23 AM   #6
jeff968's Avatar
Quote:
Audi sent out a supplemental replacement page for the manual a few years back indicating the timing belt doesn't need to be replaced until 110K miles. If you are not registered with Audi you should get yourself registered. Then they'll send you these type of things. I have the page. Send me a PM with your email and I'll scan you a copy and send it to you.
Jeff
jeff968 is offline   Reply With Quote
Old 02-16-2012, 07:16 AM   #7
Thanks Jeff. I was able to get the revised service list from the dealer showing the 110K change. When you say "register with Audi" what do you mean exactly? Have bought two A4s new but have not registered....or at least I don't remember being registered for anything. Thanks! Dan
Old 02-17-2012, 02:06 PM   #8
Owners with new cars are automatically registered with Audi for any extended warranty updates that they may make. It's suggested that folks who buy used Audi's, register with Audi (there's a form in the owner's manual) so that if there are any new updates, the current owner will get properly notified.
Thread Thread Starter Forum Replies Last Post
S3 versus the Mk 3 TT. Some info from C&D Lightning Lap Vegas-roadster TT (Mk3) Discussion 4 09-26-2015 12:09 PM
2011 vs 2012 A8 Changes Mike_k A8 / S8 (D4 Platform) Discussion 1 09-25-2015 07:21 PM
average "New To Me 2010 A4" post brjones A4 (B8 Platform) Discussion 0 09-23-2015 10:32 PM
Rear thumping noise over bumps Avantadrive_Original A4 (B7 Platform) Discussion 1 09-14-2015 01:11 PM
New To Audi!! JWhite1089 New Member Welcome Area 0 09-05-2015 09:37 PM
Tags
20, 2007, 2007a420timingbeltorchain, 20tfsi, a4, audi, belt, chain, engine, jetta, location, number, quattro, serial, tfsi, tfsienginetimingbelt, timing, turbo
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
