How is the timing chain involved when replacing a crank seal
Old 11-10-2015, 08:07 AM
checkpoint's Avatar
Default How is the timing chain involved when replacing a crank seal
How do you have to manipulate or come into contact with timing chain on a 2009 2.0t
Old 11-10-2015, 11:37 AM
Prospeeder's Avatar
You talking about the front seal. The thing about it is, The pulley, and the sprockets for the timing chains are held by that center bolt. It is possible for the sprockets to come off and timing would jump and according the the book, says the engine can be destroyed from this happening!
Personally I have had 4 of these apart, none of them had this happen. On the ones I was doing chain on, I could see just how small the little "shelf" is that is passively holding them there without the bolt. What I do to be safe, is remove the upper cover, run the engine to the mark so the cams marks are pointed up. Then remove the bolt holding the pulley, and slowly and carefully remove the pulley, then I put something like a socket, or piece of plastic pipe and carefully thread the bolt back in and hand tighten it so it holds the timing sprockets safe. Then do your seal.
soSerious
12-12-2008 01:44 PM
Squire
12v V6 Discussion
14
01-09-2007 09:16 AM
515
Audi 100 / A6 (C4 Platform)
05-14-2005 01:03 PM
GDA4
07-04-2004 05:43 PM
Rebel_Audi
12
01-06-2003 03:42 AM
Quick Reply: How is the timing chain involved when replacing a crank seal
