Deleted N249 Throwing Codes
Old 03-25-2016, 07:26 AM
MINIHammer's Avatar
Default Deleted N249 Throwing Codes
A couple months ago I bought a stg3 S4 Avant, it ran strong and boosted to 23 psi. 2 weeks ago I was driving home and the car bucked and went into limp mode, after cycling the ignition I was able to drive again but only could get 20psi. This works for a little while but it eventually goes back to limp mode and only gives me 6psi. I have an air/fuel gauge and before everything it was pretty constant somewhere around 14/15, now while stopped or idling it drops down to 10 and sometimes up to 16/17. Driving brings this back to inline to what I understand is a good afr, just no boost.
I had the car scanned via vagcom last week and the codes called out the N249, which has been deleted along with the pcv. The valve is gone and no resistor so I believe it's been coded out. Right now all I have are the fault codes but I just purchased a vagcom so once I find a laptop I can provide more information.
Any ideas?
Address 01: Engine Labels: 078-907-551-AZA.lbl
Control Module Part Number: 8D0 907 551 M
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 06752
Work Shop Code: WSC 87119
VCID: 3467E38104FE309EA5-5124
5 Faults Found:
17695 - Boost Pressure Control Valve (N249)
P1287 - 35-00 - Open Circuit
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17965 - Charge Pressure Control
P1557 - 35-10 - Positive Deviation - Intermittent
17535 - Fuel Trim; Bank 1 (Mult)
P1127 - 35-10 - System too Rich - Intermittent
17537 - Fuel Trim; Bank 2 (Mult)
P1129 - 35-10 - System too Rich - Intermittent
Readiness: 0000 0000
Old 07-26-2016, 09:54 PM
auditna's Avatar
If it's an open circuit, it knows it's not plugged in. I don't think it's been coded out.
You can get resistor from urotuning like this one SAI_Resistor_Square SAI Delete Resistor, Square Connector
maragh
10-24-2016 05:44 AM
LMSI-G35X
04-13-2013 07:53 PM
krem22
Audi allroad
10-12-2009 06:16 PM
Python021
08-30-2009 07:06 AM
Greg225TT
01-19-2006 01:44 PM
Quick Reply: Deleted N249 Throwing Codes
