motor swap car won't crank p0600 code
Old 06-30-2016, 07:18 PM
Shaine Scheetz's Avatar
Default motor swap car won't crank p0600 code
Ok I had an alroad 2.7t 02 I was rear ended car was totaled so I pulled the motor and bought a sedan 02 2.7t a6 with a blown motor did a full motor and trans swap still auto just didn't want to pull the trans off the motor can't get the car to crank at all I get clicking in the engine bay like stuff turning on but no crank getting 3 codes p0600 p0113 p0118 is this just an ecu problem that is not communicating with the motor and needs to be reprogrammed or what else could it be grounds look good unless I'm missing one ecu and wire harness stayed with the sedan
dragpro
A6 (C7 Platform) Discussion
12
02-23-2015 08:00 AM
2k3s2k
06-22-2014 04:48 PM
slowguy
12-02-2012 04:52 PM
BASELINE
10-15-2004 02:48 PM
fast 2.7t 343 hp
03-03-2001 09:35 PM
Quick Reply: motor swap car won't crank p0600 code
