Oil on spark plug, bad rings, head or worse?
Old 11-06-2016, 07:52 AM
ReevesL's Avatar
Default Oil on spark plug, bad rings, head or worse?
Short version: oil on end of one coil pack and top of spark plug, possible causes?
Greetings AudiWorld,
I'm hoping someone has some advice on where I should focus my investigation to diagnose this.
I'm prepping to pull a 2.7T out of an A6 to put into my A4. As part of checking over the motor I pulled the coil packs and the spark plugs and did a compression test. There was oil on the end of the #3 coil pack and on top of the spark plug. There was some oil on the threads too, but that likely came during the pulling of the spark plug.
I did a compression test next and #3 piston was around 200 while the remaining pistons were all about 160.
The engine will be pulled for the swap, so I'll have full access when it's on the stand.
I did a search in this forum and across the whole board but came up empty handed (or didn't use the right keywords).
Thanks
emmm
21
01-18-2023 04:27 PM
digimurda
20
01-17-2018 03:57 AM
hitrun222
05-15-2012 06:44 PM
popdemonic
Audi Original "S" Cars
04-29-2008 05:14 AM
MC Hammered
05-07-2007 02:01 PM
Quick Reply: Oil on spark plug, bad rings, head or worse?
