Please help 2001 S4
Old 10-01-2016, 03:38 PM
michael.latraille@gmail.com's Avatar
Default Please help 2001 S4
I had to replace the Aux water pump because it was leaking, I also had to replace the PCV spider hose because it was brittle. now that i put it all back together the oil can on the dash is on. I changed the oil and the level is fine. I am thinking I messed up a sensor but not sure which one is which. can someone please tell me where and what sensor it is.
Thanks
Michael
Old 10-06-2016, 02:07 PM
transman's Avatar
Its by the oil filter housing. Remove the oil pressure switch and hook up a manual gauge and make sure your car has correct oil pressure.
Old 10-06-2016, 02:56 PM
the_duke's Avatar
Which oil can? Red or yellow? Red is the pressure sensor mentioned above. Yellow is the level sensor which is located in the bottom of the oil pan. Most likely you've dislodged a wire causing this issue but you could just be unlucky and have had a sensor failure. It's unlikely you have developed a sudden oil pressure issue.
Jgarcia1910
01-14-2014 07:04 AM
mpoo83
13
10-09-2011 05:45 PM
UK_Audi_A4
12-28-2007 05:42 AM
big_anthoiny
11-27-2006 04:53 PM
aerohr
13
03-22-2006 05:03 PM
Quick Reply: Please help 2001 S4
