Check Engine Light after T-Stat Replacement
Old 01-11-2017, 09:35 AM
magill's Avatar
Default Check Engine Light after T-Stat Replacement
I have a 2011 3.0T A6 and I replaced the T-Stat over Christmas. All in all not a bad job (but the most evolved t-stat I have ever done). However... I either have an Electrical plug in the wrong spot or created a vacuum leak.
Car still runs fin, however I am getting a set of error codes to do with the Evap system and the flappers in the intake (1st Question, What purpose do those flappers serve?).
There was no carbon build up, so if I had put it back together correctly, I should not have an issue.
The only symptom (other than CEL) is that if you shut the car off, take off gas cap (refuel) when you restart it will stall after about 3 seconds and restarts a bit hard (5 or 6 seconds of cranking).
Error codes show up usually after 2nd start when you clear them -- sometime 15 - 30 miles down the road, today they did not come back, but I am sure It will on the way home.
I think maybe I swapped the electrical connectors on the 3 vacuum solenoids on the back of the engine or maybe got something stuck in the flappers mechanically (external where the vacuum motors connect)
I thought I marked everything well, but maybe I did not -- how do I verify wires and vacuum lines? Thanks for the help
They are in order of entry:
001109 - EVAP System
P0455 - 000 - Large Leak Detected - Intermittent - MIL ON
008196 - Intake Manifold Flap; Bank 1
P2004 - 000 - Stuck Open - Intermittent
008197 - Intake Manifold Flap; Bank 2
P2005 - 000 - Stuck Open - Intermittent
1170 - Secondary Air Injection System: Bank 2
P0492 - 000 - Insufficient Flow - Intermittent
001169 - Secondary Air Injection System: Bank 1
P0491 - 000 - Insufficient Flow - Intermittent
08198 - Intake Manifold Flap; Bank 1
P2006 - 000 - Stuck Closed - Intermittent
008199 - Intake Manifold Flap; Bank 2
P2007 - 000 - Stuck Closed - Intermittent
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent - MIL ON
Cirrusaudi
08-29-2018 09:04 AM
Newt190
RS4 (B7 Platform) Discussion
06-02-2010 07:23 PM
jimweisptd
Audi 100 / A6 (C4 Platform)
09-19-2007 03:48 PM
SlvrAvnt30
06-12-2007 09:48 AM
PDX95A6QWagon
12-30-2006 12:24 PM
Quick Reply: Check Engine Light after T-Stat Replacement
