engine noise after thermostat. replasement
Old 07-17-2011, 08:02 PM
yunkyaidi's Avatar
Default engine noise after thermostat. replasement
Hi, everyone; I just replace the thermostat on my 2000 AUDI a4 3.0 and I end-up with a very loud noise coming from the right side (valve cover) after I finished it. When I loose the timing belt tension I did not move anything other than the belt from the right side Cam, I did fallow the instructions very close. What I did wrong?.
It sound like bad piston or bend valves, if that the case, how that happened?.
Thank for anything
Old 01-15-2014, 04:12 PM
Jabroni1485's Avatar
Did you mark the belt / gear so you would be sure to get it on in the same exact spot?
Old 01-15-2014, 04:15 PM
My bad, not used to reading forums that are so old :P
Old 01-15-2014, 07:16 PM
Prospeeder's Avatar
yea I know this is the strangest setup forum I have ever used....If you dont set every setting just right it shows old stuff, and shows threads backwards ect....
Old 12-22-2014, 06:01 AM
x19
x19's Avatar
Default Did you fix or ?? we are so curious for this problem
Thank for anything
Hi, what was happening on your engine ? One teeth was off and hitting each other( Valves and piston)? etc.
phantombox
01-23-2017 03:46 AM
corneliusmix
05-20-2013 07:10 AM
frepetto
13
11-25-2008 08:40 AM
bil_c
03-26-2007 10:16 AM
PHANTTOM
08-29-2001 05:50 PM
Quick Reply: engine noise after thermostat. replasement
