Mild vibration and idle sound
Old 01-15-2016, 08:44 AM
sb6r's Avatar
Default Mild vibration and idle sound
I've got a 2010 S4 (around 60K miles).
Both videos are after driving 20 miles (warmed up) and with 93 octane on board.
Does this idle sound normal?
Is the vibration (on the hose) normal at idle?
Any insight would be appreciated!
Thanks.
Old 10-23-2016, 06:25 AM
vboolcha's Avatar
IMG 5874 - YouTube
IMG 5873 - YouTube
Thanks.
Did you ever figure this out? I am having the same problem on my a6. 66k miles. 2013 same engine
Old 02-01-2017, 11:51 AM
js154's Avatar
Get an OBD2 scanner and see if you get a fault code for ignition coil(s). You'll need a VAGcom tool and software to properly reset it. Coils are cheap.
Old 02-11-2019, 06:45 PM
abelleandro's Avatar
Default I have same issue
I have an A6 prestige 2015 mine doesn’t sound that much the engine but it shakes when the car not move i brought it to the Audi and they said that was the fuel injectors. After they fixed the injectors the car still have same problem and they found out that it was the camshaft that was broken on bank 2.
IMG 5874 - YouTube
IMG 5873 - YouTube
Thanks.
chrisx348
S7
06-08-2022 06:45 PM
projek_01
Q5/SQ5 MKI (8R) Discussion
10
01-04-2019 09:41 AM
Dipthe0ry
Q5/SQ5 MKII Discussion
13
10-01-2017 10:49 AM
popdemonic
Audi Original "S" Cars
05-08-2008 05:48 PM
Quick Reply: Mild vibration and idle sound
