2.8 missing
Old 05-28-2014, 10:28 PM
surge0072002's Avatar
Default 2.8 missing
i have a 2001 Audi a6 2.8 quattro and its missing real bad now as soon as i start it up. before it was just here and there and i thought it was because of my valve covers leaking but i replaced them and it did ok for a day and got bad. i tested the coils and plugs with ohm tester and they were all good and i have ac-delco plugs and gaped them all to .32 as i think they are suppose to be. but my codes were this even before the valve cover change so if any one has any ideas or has had this problem or can figure it out i would greatly appreciate it. plus the o2 readings i think are from my flex pipes being bad will replace them this weekend
p0300- malti misfire
p0301- cyl 1
p0306- cyl 6
p0159- 02
p1393- ign coil output
p1522- camshaft adj bank 2
p1176- 02
p1177- 02
Old 06-02-2014, 01:18 PM
CRuby's Avatar
You mention codes were this before VC change. Did you clear them in-between? Camshaft sensors, coils, & O2 sensors do go bad. Bank 1 & bank 2 use same camshaft sensor, so you could remove & switch them, to see if code follows the sensor. Could do similar swap with coils on cyl 1 & 6. Obviously not with each other, since they both could be bad, but switch 1-2 & 5-6. Clear codes & retest. If 2 & 5 now bad, change them.
Old 05-21-2015, 01:22 PM
ynot5105's Avatar
Check, or have your lambda sensors (Oxygen ) checked. I had one reading a too lean mixture on the one bank, requesting the injectors to pump fuel, leading to over-fueling and misfiring.
Regards
AudiNike12
01-18-2019 12:34 PM
DaveOx
Audi allroad
14
03-02-2017 07:06 AM
xlilmama10211x
03-23-2016 09:56 AM
antipodeman
10-19-2011 06:55 AM
Flippa_S4
04-01-2009 10:14 AM
Quick Reply: 2.8 missing
