First Audi
Old 08-07-2016, 04:07 PM
dbauer428's Avatar
Default First Audi
Just picked up a 2002 Audi A6 3.0 for my son. 150,000 miles. Runs excellent but developed a coolant leak a few days after purchasing. Leaking drivers side of rear engine. Can't pin point leak. Replaced Throttle body. Double checked for leaks. Can't see any leaks under rear of intake. Once leak started we lost speedo. I checked speed sensor and leak caused speed sensor to get wet. So leak is above or close to drivers side wheel speed sensor. Cars temp stays at middle of gauge. Needle never budges on on water temp gauge. I am leaning towards auxiliary water pump. Any thoughts?
Old 08-07-2016, 08:10 PM
dbauer428's Avatar
Default Intake off
Looks like drivers side pipe that connects both heads with coolant is leaking. Is that a gasket, o ring or silicone seal on that pipe?
Old 08-07-2016, 10:10 PM
dbauer428's Avatar
Default Might have find it.
Hmm....,,Just out side of the coolant pipe that runs between the heads is another piece bolted to both heads. The left one has a Allen screw in one home. And glue/silicon in the other. The right side has a Allen screw and nothing in small hole. Could this be my leak? What is this part?
Old 08-07-2016, 10:13 PM
dbauer428's Avatar
Here is the piece. Silver top.
[/QUOTE]
Old 08-09-2016, 08:40 PM
Prospeeder's Avatar
Theres a coolant nipple that threads into the big water manifold that connects both cylinder heads and goes under the intake, those will leak. There is also the 2 orings on the water manifold to cylinder head, as well as the quick connect heater hose fitting that commonly leaks.
Old 08-09-2016, 10:10 PM
dbauer428's Avatar
Default Thank you
I found the leak this evening. It's dripping directly above my wheel speed sensor on drivers side. I can now see it leaking from the top. But will have to remove TB to get a better look at. I had intake off this week. Replaced O rings on left pipe that goes under intake. But no leaks under intake. So I am making progress. Thanks again. Stoked for my son to have this for his first car...!!!! 😀
Picked up car for $900
Old 08-10-2016, 06:42 PM
Prospeeder's Avatar
Hey pull the large plastic cover off over the battery and master cylinder area. The 2 heater hoses can leak, and create a pin hole and pee out coolant. The drains for the coolant are right by the steering rack.
Old 08-11-2016, 04:47 AM
dbauer428's Avatar
Default Heater hose quick disconnect
Leak was top heater hose quick disconnect O ring. I already had a O ring kit. Fixed it last night. 👍✌️
juno
Audi allroad
27
12-22-2020 03:53 AM
joermk
A4 (B7 Platform) Discussion
11-29-2018 06:23 AM
Solem
01-06-2016 09:03 AM
catch2otwo
11-27-2010 09:49 AM
djdavealbert
05-30-2009 12:12 PM
Quick Reply: First Audi
