Coolant temp sensor
Old 01-10-2008, 07:33 AM
einnod17's Avatar
Default Coolant temp sensor
Replaced the sensor last night. Wasnt as easy as I has hoped. Talk about a knuckle scraper. Doesnt look like I even needed one though. Think cluster is busted. Gas and Temp guage work only ocassionally. Was hoping it was just the sensors, but guess not. I heard the cluster is really expensive. Just have to rely on distance to empty and hope the car isnt overheating. Anyone else had a bad cluster?
Old 01-10-2008, 02:37 PM
Tech Guru
4Driver4's Avatar
VAG-COM is your friend.
Old 01-11-2008, 07:22 AM
einnod17's Avatar
Default Re: VAG-COM is your friend.
I had heard that a bad coolant temp sensor sometimes wont trip the computer. Do you know how to diagnose a bad cluster? Would that trip the computer?
Old 01-11-2008, 02:24 PM
Tech Guru
4Driver4's Avatar
Default Use VAG-COM to check the cluster for faults and check inputs from various sources.
There's a lot more to VAG-COM that pulling a few codes from the ECU.
Old 01-13-2008, 07:40 PM
V8BOB's Avatar
Default Look at the web site bba-reman dot com, sounds like they
repair clusters with problems like yours. I have no experiece with them just passing along some info.
bluenote
12v V6 Discussion
06-26-2007 08:15 AM
cbons
Audi allroad
04-22-2007 04:16 PM
LCP
12-06-2002 09:51 PM
S4V8
09-15-2001 03:54 PM
audicommuter
05-08-2001 01:10 PM
Quick Reply: Coolant temp sensor
