Timing question
Old 03-31-2015, 06:57 PM
rusty1428's Avatar
Default Timing question
I replaced the cam chain tensioner gaskets and as i was rotating the engine with the timing belt on. I was using a wrench. I noticed the tb tensioner was falling off. Noticed the bolt was stripped probably by previous owner because it all looked brand new. question is I didn't get it back to tdc before I removed the timing belt. Do I need to move the cams and everything to tdc before i put the belt back on? Everything is still lined up?
Thank you
P.S I am new here and if there is a thread on this already i apologize
Old 04-03-2015, 12:47 AM
bydand's Avatar
Default In a word: Yes, you need to confirm the timing!
Not clear what you have done? Removed the cam chain tensioners & cams, or only lifted the chain tensioner, and slid the gasket in. Before removing the belt?
Anyways, yes I would reconfirm the timing of the cams and crank.
Do a search for the area you want details on, etc etc.
How to set the timing on a 97 A4 Quattro V6? - AudiForums.com
Bydand
gmachinedart1
30v V6 Discussion
10-23-2012 01:03 PM
bsherwoo
08-14-2008 10:08 AM
galvan11
07-26-2008 10:49 AM
chewbacca
09-30-2006 02:38 PM
ePuFFy
03-26-2005 07:49 PM
Quick Reply: Timing question
