Uh oh? 3.0 avk
Old 04-20-2016, 07:41 PM
Cummins guy's Avatar
Default Uh oh? 3.0 avk
Cleaning engine while waiting on parts and came a cross a hole on the block. Can anyone tell me what would have caused it and if it's shot..
Lh side by oil filter and ac compressor
Just am curious if I can run that way. You would think there would be a lot of oil in the area. Most of the oil came from the power steering hose that was leaking
Old 04-26-2016, 05:08 PM
Prospeeder's Avatar
Wow thats strange, well if its been running ok up until its discovery, its probably ok. I would be inclined to maybe clean the area and patch it with something, maybe a small bit of metal and some JB weld.
Old 04-27-2016, 05:36 AM
N_Jay's Avatar
Are you sure the hole in in the block, and not just a space between the block and a bolted on accessory?
Old 09-19-2019, 06:46 AM
Nico Basis Foncea's Avatar
Default I’ve the same problem
I’ve the same problem, I just take the engine out because the automatic transmission are having issues, now the engine had a lot of oil leaks. Taking the block on the engine bank, I saw that hole! And it’s not minor, what you do to fix it? And the fix came with another issues? I think that the pressure is very high? Or the installation of the a/c compressor are brokered?
Old 06-01-2023, 06:33 PM
Victorymike18's Avatar
I came across this old thread from searching, since I found the identical hole on my 3.0L engine.
Has anyone successfully patched this? It seems to be a non critical area, so I'm wondering if the solution is as straightforward as a really good cleaning and some JB Weld?
Regarding the cause: I'm going to guess that this was simply a thin spot in the casting molds that was overlooked and made it to production.
Old 09-24-2023, 01:52 PM
Kind of a minor update to an old thread, but I was poking around and I'm starting to doubt that this hole actually leads into the crankcase / oil pan area. It seems (yet to fully confirm) that this is kind of a dead space that is sealed off. And I found a couple of similar holes along the Driver side of the block which are inconsequential... So ultimately it might not be an issue at all.
Old 02-12-2024, 10:45 AM
TT-S4's Avatar
Hmm....?
Very interesting.
The metal there is extremely thin.
Right above it is a bolt.
Is that bolt holding, perhaps, that thin cover?
Seems a good number of owners are seeing a hole in the same area.
Given the many under engine covers on these vehicles, I wonder what caused the hole/break?
Initially I thought perhaps it's an area where rocks can easily get kicked into that space, but given the aero, under engine covers, I'm not sure.
Do the under engine aero covers cover that area or not?
Old 02-13-2024, 05:22 AM
Ah, good time for an update. I have the lower oil pan off and had a machine shop clean the engine. I've since done a lot of poking around with a flashlight from underneath and I am quite confident this is not actually open to the oil pan / crankcase. It seems to me it's an independent little chamber and the chip doesn't matter. I get the feeling that I could actually open the hole up further without consequence and may even do that just to inspect & clean it out...
I don't own a B6 so I can't comment about the engine covers.
And that bolt is likely one of the side mounted bolts fastening the crank main bearing caps?
Here's a photo where you can see there's a "floor" to the chamber, and you can even see some of the beige sealant towards the inner left side.
Omega Supreme
12-16-2007 08:40 AM
3Scanner
12
03-15-2006 11:35 AM
A4orce84
10-04-2005 04:16 AM
whitacre
03-16-2005 09:21 PM
Speedy
03-11-2002 09:51 AM
Quick Reply: Uh oh? 3.0 avk
