B6 S4 Engine rattle at RPMs
#11
Sunday,01,January,2017,21:04:00:50181
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64)
Data version: 20161129 DS267.0
Ross-Tech: Home
VIN: License Plate:
Mileage: 184530km-114661mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUPL68E94A181363 Mileage: 184530km-114661miles
Address 01: Engine Labels: 079-910-560-BBK.lbl
Part No SW: 8E0 910 560 UM HW: 8E0 907 560
Component: 5.0 91Oct JHM G 0010
Revision: 00000000 Serial number: AUZ6Z0C0389004
Coding: 0007711
Shop #: WSC 78390 536 452134
VCID: 0407D8E244DF1A62ED-515E
2 Faults Found:
18613 - Performance Malfunction in Cooling System
P2181 - 008 - - Intermittent
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04595
Shop #: WSC 06435
VCID: 3663722A128378F223-5124
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AC
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
VCID: 62CBFE7AEE8BB452BF-5140
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
VCID: 356175260F8573EA2A-4B00
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Shop #: WSC 63351 000 00000
VCID: 3F8D170E6DB9B9BAF0-515E
1 Fault Found:
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
001 - Upper Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 02041
Shop #: WSC 63351
VCID: 3E736A0A3AB3B0B2FB-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 981 G
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 05141
VCID: 31694136FBED5FCA76-5140
WAUPL68E94A181363 AUZ6Z0C0389004
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
VCID: 71E981363B6D1FCA36-4B00
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 11848
Shop #: WSC 63351
VCID: 72EB8E3A3E6B24D2CF-4B1A
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0004
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0004
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0004
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0004
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 0407D8E214DF1A62ED-4B32
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0410
Coding: 01205
Shop #: WSC 70656
VCID: 2C575042DCCF322245-5092
End-------------------------(Elapsed Time: 05:59)--------------------------
#12
Gruven,
A few things:
1 - post the issue on the B6 S4 forum to ensure you get a wider audience
2 - the block 093 might not be applicable to the B6 model, unlike the C6. Even though both engines are 4.2 they are not identical.
3 - when you pull a log, what errors are you seeing?
Have you changed coilpacks, sparkplugs, ...the usual items related to a misfiring engine?
A few things:
#13
So I figured out the problem with the help of my mechanic. We determined that the rattle came up at about 2200 rpm. We put it up on the lift and revved it up, and it turns out that the alternator shakes at that rpm, which is causing that noise. So odd.
In the coming weeks, I'll put it into service mode and figure out how to fix it.
I appreciate all the help.
m@
m@
#14
GruvenS4,
How'd this scenario work out? my 2004 S4 started doing the same thing! I haven't had it on a lift to see if the alternator is the cause yet, but this gives me hope that I'm not having to figure out whether or not to get rid of the car over the guide/tensioner failure... I did notice a day or two BEFORE this happened that the car seemed to be whining more than usual so maybe this was a premature sign of the alternator mechanical starting to give-way? I have not noticed any issues with electrical problems but maybe this is just the mechanical bearings or a bad pulley on the alternator?
Looking forward to hearing your final story!
Thanks!
Thanks!
#15
GruvenS4,
Thanks!
Thanks!
Hey Brandon -
I'm really not sure what caused this bolt to break in place the way that it did. Only the last 1" of the bolt broke off, which allowed the whole thing to oscillate in that particular rpm range. Had I not had it on the lift with the belly pans off, I probably never would have found it. I replaced the bolt after taking out the alternator. It was a huge pain in the *** if I remember right.
As another discovery at the time is that there was oil all over, and I couldn't figure out where it was coming from. The valve cover gaskets were leaking, which poured oil all down the front and sides of the block, causing a huge mess. It didn't zap the alternator, but it could have. On my 535ix, there is a gasket at the base of the oil filter on top of the engine that is notorious for failing, and it did on mine. It allowed oil to drip below onto the alternator, which killed the bearings on the alternator. I had to replace the alternator on that car, along with the gaskets. It had a whine similar to what you're talking about. The way I diagnosed it on that car was to use a stethoscope and touched the casing of the alternator and you could hear the bearing through that. The poor man's version of that is just to use a piece of dowel and touch it to your head.
Good luck. Reply again if you think of anything else I can help with. Matt
