2004 s4 clutch not disengaging
Old 02-26-2017, 10:58 AM
J_mercier's Avatar
Default 2004 s4 clutch not disengaging
Hi there I recently changed my flywheel and clutch on my car. Of course with this being said I changed the throw out bearing clutch fork and pressure plate as well. My problem now is that the clutch pedal dosnt seem to be disengaging the clutch. I've bled the system about 6 times now so it has absolutely no air in it but still acting like the slave cylinder is not pushing the fork arm far enough to disengage it. It starts in neutral vary nicley, but when trying to start it in gear or select a gear while running it will not go into the gear or it moves when you turn it over if you have it in gear. If anybody has any advice this would be much appreciated as I am almost stumped haha. Brand new slave as well.
muccamoofrog
Audi A5 / S5 / RS 5 Coupe & Cabrio
11-25-2018 08:09 PM
jmerber
12-22-2016 11:09 AM
AudiSport4000
01-30-2006 11:49 AM
HaVoC
10-10-2005 01:45 PM
paul s-car
04-21-2003 10:02 AM
Quick Reply: 2004 s4 clutch not disengaging
