Carbon buildup
#11
On the contrary, it is expensive. The intake manifold does not just pop off. There is a lot of interference to be removed--fuel lines, etc. it is very labor intensive so probably several hundred dollars. With respct to detergent gasoline it does not help the back side of the valves because it does not come in contact with them. Also it seems that much of the carbon comes from crankcase ventilation.
#12
True, but the cost is considerably less than the old method of removing the manifolds and soaking them in a cleaning solution for a couple of days. That process is significantly more labor intensive and costly than the $400-$500 of a walnut pressure cleaning.
#13
Audi service can do the work, I believe it's 3-4 hours T&M.
#14
This is sounding a little better. I watched a video on the soaking method which seems quite laborious. I recall from Navy days that crushed walnut shells were fed into a running turboprop engine on P3s. I also read a piece from a UK source suggesting again that operating at 3000 rpm occasionally will help and noting that slower turning V8 DI engines experience carbon more often. Thanks for all the helpful posts.
#15
Just to clarify, the walnut shell process on a DI engine is done without the motor running. In fact, great pains must be taken to avoid any of the shells from entering the open ports before cleaning and after the shells are vacuumed out. I can't imagine what would happen to the valves if there were shells remaining when the engine was started.
Beakerz
11
03-29-2011 09:29 AM
|skolnick
07-14-2004 08:19 AM
