Hot spot on transmission tunnel
Quick question for other owners. I bought a 2017 Allroad (Prestige, warm weather package if that matters) about 6 weeks ago. In driving, I've noticed a very warm spot on the transmission tunnel next to my right leg. It gets up to about 110-118 degrees in regular (not "spirited") driving, but does vary for some reason. The spot is on the side of the transmission tunnel, about even with where the cupholders are on the top.
Has anyone else noticed anything similar or can say if it's abnormal? Thanks in advance....
You mean near the drivers side area? Not the transmission tunnel in the rear passenger area? I've done some spirited driving and some long road trips and never felt it heating up near the drivers side area. No idea about the passenger area since I've been there like twice.
Thanks, Vipin. Yes, on the hot spot, right where my right leg sometimes rests on the transmission tunnel (it's already shorts weather in California, sorry). I also had a passenger the other day and confirmed it's warm on that side, too. I stopped by the friendly dealer and have an appointment to have it checked out Thursday. I'll update when I find out what it is.
Thanks, just checked the rear seat, temp is set at 64. And it's only a hot spot on the tunnel, about 3" across on the plastic part of the tunnel. The carpet coming up the side below the hot plastic is also a little warm, but doesn't feel as warm as the plastic. That might be just insulating quality of carpet vs. plastic. The service tech I spoke to when I made the appointment (in person) thought it might be coming from the exhaust that's routed along the transmission tunnel. I'll know more after they do their thing on the 16th.
Ding, Ding, Ding!
And the prize goes to Tenspeed, with archrenov8 as runner up!
Here's what I found out. The rear seat heating duct does pass along the tranny tunnel, so that's where the heat was coming from. And it's because the A/C system sends heat to the rear compartment any time the system isn't in "Synch" mode, so there's on-demand heat available to the rear whether they're calling for it or not. If no heat (or not enough) is being called for in the rear compartment, the duct gets hot.
Note that any time a front or rear passenger adjusts the temp setting, the system defaults to 3-zone, so you should re-set to the "Synch" setting after you kick their whiny butts outta your baby and lock the doors.
