2000 Audi A4 will not start
Old 05-12-2016, 08:20 AM
snatchman's Avatar
Default 2000 Audi A4 will not start
I have a Audi A4 2000 that will not start. I have narrowed it down to the clutch, either a safety switch or an relay. I have jumpered the safety switch that is attached to the clutch pedal and I am still getting the message press clutch in to start. So is there an relay I can check? Plus I have read in another thread that the convenience module in the trunk can cause this problem. How do I locate this module in the trunk? I also ran a scan, please let me know if you see something in the codes.
Thursday,12,May,2016,12:05:44:04768
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
Ross-Tech: Home
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 058-906-018-ATW.lbl
Part No: 4B0 906 018 P
Component: 1.8L R4/5VT G 0006
Coding: 07001
Shop #: WSC 06335
VCID: 2E53E54DEA05E54EDC-5140
5 Faults Found:
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
16825 - EVAP Emission Control Sys
P0441 - 35-10 - Incorrect Flow - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS
P1606 - 35-00 - Electrical Malfunction
16725 - Camshaft Position Sensor (G40)
P0341 - 35-00 - Implausible Signal
17925 - Power Supply Relay for ECU
P1517 - 35-10 - Electrical Malfunction - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 B
Component: ABS/EDS 5.3 FRONT D00
Shop #: BB 24332
VCID: 1D31328197A36ED675-5122
No fault code found.
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 K
Component: Airbag Front+Seite 1002
Coding: 00104
Shop #: WSC 06335
VCID: 3E73D50D3A6515CE4C-517C
9 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
32-10 - Resistance Too High - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
33-10 - Resistance Too Low - Intermittent
00589 - Airbag Igniter 1; Passenger Side (N131)
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
01218 - Side Airbag Igniter; Passenger Side (N200)
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 C
Component: B5-KOMBIINSTR. VDO D11
Coding: 02244
Shop #: WSC 00000
VCID: 2B55EC59D9179066FB-5140
1 Fault Found:
00667 - Ambient Temperature Signal
30-00 - Open or Short to Plus
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06335
VCID: 408FABF54091633E3E-4EB2
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
VCID: 60CF4B75E051033E1E-4B32
2 Faults Found:
01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
35-00 - -
01382 - Alarm triggered by Anti-Theft Sensor; Front Left
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00011
Shop #: WSC 06335
VCID: 65C15A61FF736616ED-51B6
End-------------------------(Elapsed Time: 04:09)--------------------------
Old 05-12-2016, 10:28 AM
clancy's Avatar
We had a no start, no starter, nothing issue on a 2001 A4 a while ago. I read about 3 common causes, the clutch switch, the convenience module, and the ignition switch. I decided the try the simplest repair first and jumped the clutch switch as you mentioned. The "depress clutch" message still illuminated, but the car started nevertheless. I was lucky. Don't know why that message stays lit with the switch jumped and the clutch depressed, but it starts fine. Starts whether the clutch is depressed or not. Just am sure to be in neutral.
I am concerned about the "17925 - Power Supply Relay for ECU". Could this be your issue?
Otherwise check into the convenience module (I think it is in the trunk area passenger side). I looked when ours did not start and it was dry and not water stained, so I went to the clutch switch.
Old 05-12-2016, 10:37 AM
snatchman's Avatar
I am leaning towards the convenience module. There is water in the trunk especially on the passenger side. I was not able to locate the module though.
Old 05-12-2016, 11:06 AM
clancy's Avatar
I am old and have forgotten the details. I believe I had to remove the carpet trim to pull off the plastic along the passenger side. Had to remove the little storage compartment to get to a screw. Pull out that plastic side and the module will be evident.
Old 05-12-2016, 11:24 AM
snatchman's Avatar
Thanks Clancy, I found it and have one on order now.
Skidaddie
06-21-2023 10:40 PM
Darwould
06-21-2014 02:41 PM
Tony E Carter
03-11-2012 04:21 PM
jeanfor
Audi allroad
09-19-2006 09:31 AM
adg44
09-16-2002 03:14 PM
Quick Reply: 2000 Audi A4 will not start
