2001 a4 quattro brake light warning light
Old 01-22-2015, 07:40 AM
sam06108's Avatar
Default 2001 a4 quattro brake light warning light
Every time I hit the brake the brake light warning light goes on. Obviously checked all the lights to see if they functioned. The front turn signal also blinks whenever i apply brakes. When I turn on headlights the high mounted light turns on as well. Please help the beeping from the warning is annoying the hell outta me.
Old 01-22-2015, 04:34 PM
Prospeeder's Avatar
Well the little tail light circuit board, the thing all the bulbs push into, in the tail lights are known to cause intermittant on off warnings. Also if you put the wrong bulb in, say a single filament bulb into a socket designed for 2, it will cause all sorts of funny things.
Old 01-23-2015, 09:42 AM
sam06108's Avatar
Hopefully its just a matter of changing the bulbs . however is it possible to switch out the circuit boards you mentioned, if the bulb switching doesn't work. I'm sorry if its a dumb question I'm new to Audi just purchased the car a month ago.
Old 04-19-2015, 06:11 PM
audinary's Avatar
Hi Sam,
have you fix the annoying brake warning light?
I'm having the same problem.
Old 04-20-2015, 07:41 AM
sam06108's Avatar
Originally Posted by audinary
Hi Sam,
Yes I did, it actually was the single filament bulb in the brake light doing it just swapped it with dual filament and now it works. Hope that helps
Old 04-20-2015, 05:22 PM
audinary's Avatar
Good for you, I'm still figuring out mine, I replaced my tail light with euro style led light, since then it is giving problem. I read somewhere that Led light is not compatible with the CAn Bus. But I noticed as well that the auxilliary brake light on the rear seat is blown out I'll try to replace this tomorrow, hopefully this is the problem.
PearlBlackA8
Audi A2
01-05-2019 08:42 AM
marstonhouse
04-10-2010 02:28 PM
usmcB5
04-19-2009 08:06 PM
ubberwagon
Audi allroad
06-20-2008 06:18 AM
Quick Reply: 2001 a4 quattro brake light warning light
