96 A4 Dash Light Warning Lights Configuration - AudiWorld Forums
Old 01-11-2010, 08:40 PM   #1
Default 96 A4 Dash Light Warning Lights Configuration
Ok this should be an easy one for someone out there to answer and maybe get a feeling of ultimate accomplishment.
I recently, a few months ago really, took apart my dash console to replace burned out bulbs and such. In the process, the warning light "windows" (as I will call them) that show the low fuel, oil pressure, and emergency light etc fell out. I thought I put them back in the right place, but when I was down on fuel the big red check engine/EMERGENCY light came on while the fuel gauge light was off. Hence when I filled up the tank, and the emergency warning engine light went off. So obviously I have those two swapped.
But now I'm paranoid I have the others in the wrong spot perhaps, especially since I was chasing my tail on a flashing oil light when I had good pressure and a good switch! So can someone tell me the order of the warning lights?
When you look at the dash from the driver seat.. the cluster of 4 lights should read...?
Top Left Corner = Oil Pressure Light?
Top Right Corner = Water Level/Temp Light? (what does this warn of anyway?)
Bottom Left Corner = Gas/Low Fuel Light (this is where I have the other window instead placed there)
Bottom Right Corner = Check Engine/Emergency Light?
Can someone please verify and give me a heads up?
thanks!
P.S. This is a 1996 A4 Quattro 2.8L V6 with 118k miles and recently serviced about as much as you could imagine.
reinstone79 is offline   Reply With Quote
Old 01-20-2010, 11:45 AM   #2
http://audi.kris-hansen.com/cluster_bulbs.htm
again Kris was THE MAN on this as I was in same boat. Also not sure about you but MY 4 pane square is a little different from what Kris has.
Mine is as follows ( while looking at it)
water temp oil Pressure
FUEL Warning BLANK..with a cap on it.
Todd
tmanley is offline   Reply With Quote
Old 01-28-2010, 08:40 PM   #3
Dumb question tmanley, how do you know if you have a trip computer?
Er1c is offline   Reply With Quote
Old 02-01-2010, 05:22 AM   #4
Er1c, I dont understand your question. Not sure if this is considered a trip computer but I do have a seperate/zeroing mileage indicator under the odometer. As far as a COMPUTER...I dotn have the neat thing mY GTI had where you could flip between mileage since zero'd, fuel avg, current avg speed. etc.
Thread Thread Starter Forum Replies Last Post
1995, 90 Quattro - low oil pressure light/buzz at 2,100 rpms + hardipk5 Audi 90 / 80 / Coupe quattro / Cabriolet 17 11-24-2015 04:42 AM
A6 Cornering Lights jforman A6 (C7 Platform) Discussion 10 09-08-2015 11:03 AM
88 quattro cs spring chicken looking for help DannyG123US Audi 5000 / 200 / V8 Discussion 4 09-07-2015 06:53 PM
New Owner Air Suspension Questions scottnybottny A8 / S8 (D3 Platform) Discussion 0 09-05-2015 02:35 PM
95 Cabriolet Power Roof Fix. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-02-2015 10:26 AM
Tags
2004, 96, a4, audi, audi2001a4, b5, bulbs, dash, dashboard, dashlight, light, lights, list, overview, warning, warnings
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
