A4 B5 Front brake (Pads & Rotors) Replacement DIY with Pics! - AudiWorld Forums
Old 01-03-2011, 10:57 PM   #1
mksu19's Avatar
Default A4 B5 Front brake (Pads & Rotors) Replacement DIY with Pics!
Disclaimer: If you mess something up, not my fault. If you dont feel comfortable working on your car, then dont. Mechanics need to feed their children too.
Replacing the front pads and rotors is pretty easy, and if you can turn a wrench you shouldnt have any problems.
Tools needed:
A large C-Clamp
Edit: After doing this again, looks like I messed up here..the guide pins are either T40 or T45 (OE were T45, replacements were T40 on mine), and not a 7mm hex
19mm socket
Pliers and a flat head screwdriver
Whatever you use to get your car off the ground and take the wheels off.(jack/stands/etc)
Nice to have but not needed:
Syringe/something to catch the break fluid as it overflows.
Liquid wrench
Breaker bar/pipe.
Bentley repair manual
Materials:
New Pads
New Rotors
New Guide Pins (optional) Part num: 321 615 141
1. Jack up your car, and remove the front wheels. Make sure its secured on jack stands. You can do both at once, or one side at a time. Eitherway, do not use the OEM jack, as you may need to put your head below the rotor at certain times.
2. If your car has brake wear sensors disconnect them first. Follow the wire from the brake pad to the harness (circled in red below). You will need to pry the little tab and turn it 90 degrees. Then lift the harness out of the bracket and disconnect it.
3. Using a flathead and/or pliers remove the spring. (red arrows above)
4. On the rear of the caliper there are two rubber caps, one near the top the other near the bottom. Take those off, and inside you will find a T40/T45 screw. Remove both of screws, and check their condition as they may need to be replaced. Sorry, no pics of that.
At this point you should be able to take the caliper off, be careful not to rip anything. Once you get it off, secure it so that it does not fall to the ground. You can either support it on a jack stand, or tape it to the lower control arm, or anything else you see fit. If youre not replacing the rotors, skip down to step 7.
5. Removing the caliper carrier: the carrier is attached using two 19mm bolts located in the back (circled in red below). These were a real pain in the *** to break. But after half a can of liquid wrench, a broken 19mm and extension they came off. When you remove these, the rotor should come off with out any effort, if it doesnt give it a few taps to loosen it.
6. Install new rotors, and put the carrier back on. Tighten bolts to 92 ft
lb.
7. Replacing the pads: Pull out the old pads, the front one should just fall out, the rear is secured in place by a springed claw (see pic below), just pull it out.
8. Now open your brake fulid reservoir cap as you will need to keep an eye on the fluid level. Using a C-Clamp, slowly push in the piston on the caliper until you feel resistance. If the brake fluid begins to over flow, remove some of it using the syringe. I didnt have any thing to catch the fluid with, so I just put some old rags around it to absorb it.
9. Install the new pads in the same position as the old ones were located, place the caliper over the rotor and re-grease and install the screws you removed in step 4. Tighten these to 18 ft lb. If you cant fit the new pads over the rotor, then you havent pushed the piston in all the way.
10. Reinstall the rubber caps, put in the springs, and reconnect the brake wear sensors. Once you finish one side, pump the pedal a bit as that will drop the brake fluid level. Then do the other side. Once both sides are done, pump the brake pedal a few times again.
11. Final step is to properly bed in your new brakes. Follow the instructions that came with your pads, or check the manufacturers website. The instructions for my pads (HAWK HPS) were as follows:
a. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
b. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
DO NOT DRAG BRAKES!
c. Allow 15 minutes for brake system to cool down.
After step 4 your new pads are ready for use.
Finished product:
SOURCE
mksu19 is offline   Reply With Quote
Old 01-05-2011, 06:47 AM   #2
hanshy5's Avatar
Thanks for the posts! very good write ups
hanshy5 is offline   Reply With Quote
Old 01-05-2011, 02:53 PM   #3
mksu19's Avatar
Quote:
Thank you!
Thread Thread Starter Forum Replies Last Post
Brakes: Cost Pads Rotors ebod0000 A6 (C7 Platform) Discussion 137 02-19-2017 06:38 PM
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 04:46 PM
Long-term Hawk LTS Users - Any Squeal? C6Silver Q7 Discussion 15 02-23-2016 01:45 PM
Audi A4 2002 S4 6spd 98k rsixxer23 Vehicles For Sale 4 01-06-2016 04:25 AM
Brake Sensor Confusion C6Silver Q7 Discussion 4 09-01-2015 09:46 PM
Tags
12v, 2007, a4, audi, b5, b8, brake, discs, diy, front, install, pad, pads, replacement, rotor, s4
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
