airbag light reset -> vag-com general help --in PA - AudiWorld Forums
Old 12-08-2009, 09:46 PM   #1
Default airbag light reset -> vag-com general help --in PA
Have: Airbag light on
I have a feeling it is the under passenger seat connection because:
1.It is loose
2.This is the usual suspect
I've been searching posts and net for days and am getting various accounts....I know I can buy a cable, then install 409 software to get codes but,...I need to know:
a. once I have codes will this cable and software be able to reset airbag light?
b. will ver. 409 or a torrent I found w/a possible 409 crack work?
c. Do I seriously need a Rosstech unit to clear this?
d. If so, where for cheap?...I live near harrisburg, Pa?
Thanks for any help you can give me. This problem is making me loony...I've searched this site, vortex and the net for 2 days its in the way of a state inspection. (And yes I realize these cheap cables floating around are not always reliable. This is all I need it for....and the emphasis is on Cheap)
Thanks again.
marcusavant is offline   Reply With Quote
Old 12-31-2009, 02:39 PM   #2
I had a similar issue with airbag light. I hooked up my vagcom and got connector resistance fault codes. However VAGCOM would not clear the codes. I have and actual HEX+COM cable from Ross-Tech, not a cheap eBay one. So I took a chance and ordered one of those cheap airbag light reset tools from eBay since I've read some other Audi folks had positive results and wouldn't you know, it worked.
eAreEyeSee is offline   Reply With Quote
Old 01-06-2010, 02:45 PM   #3
Is there a particular reset tool you use? Most on ebay are about $50. http://shop.ebay.com/i.html?_nkw=air...tool&_osacat=0 Is that the one you are talking about?
And if you rest the airbag, but there is actually a problem with your airbag, will the light come back on (I don't want to reset the light and then not have it come on if there is a real problem with my airbag)? Thanks for your help!
orangedawg is offline   Reply With Quote
Old 01-07-2010, 02:39 PM   #4
I bought a vag-com cable usb to obdII type --used vag-com 409 with xstarter.exe . I'm not sure if i needed to use xstarter but it worked a 1 sec intervals.
this got the code and cleared it. I then found the loose connection (in the drivers left footwell, could also be under pass. or drivers seat) -yellow connector i believe with purple wires-- i reattached than zip tied it super tight, then ran vag-com again....no code was found-> problem fixed
If i hadn't found the culprit (loose connection) the code and light would have kept coming back on. Hope this helps.
Old 01-07-2010, 02:40 PM   #5
Default vag-com
oh yeah.. i got mine of ebay from a US seller. worked fine.
Thread Thread Starter Forum Replies Last Post
"Service Due" reset Cadx6 TT (Mk2) Discussion 24 12-15-2016 06:37 PM
Passenger airbag on/off switch with key in glove box Inyoury A6 (C7 Platform) Discussion 13 09-08-2015 06:04 AM
Have misfire in cyl. 4 so i swapped icm's and now it won't start period. anticsAK A8 / S8 (D2 Platform) Discussion 0 09-06-2015 06:34 AM
No Start, Need Codes Diagnosis eggsngrits A8 / S8 (D3 Platform) Discussion 0 09-05-2015 11:22 AM
Have misfire in cyl. 4 so i swapped icm's and now it won't start period. anticsAK A8 / S8 (D2 Platform) Discussion 0 09-04-2015 10:59 PM
Tags
90, a4, air, airbag, audi, b5, bag, clear, light, pa, reset, s4, tt, vag, vagcom
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
