Alarm Wiring Diagram
Ok, for Months I've searched around for a 'good' copy of the wiring color codes and locations for my 99 A4. Alas.. no luck. I managed last weekend to install a remote start with an aftermarket alarm system Intergrated into the factory system. Here's the wiring diagram/color codes I used. Remember, PLEASE check your wires with a multimeter.
1999-2000 AUDI A4
ITEM | WIRE COLOR |POL|WIRE LOCATION
12V|red |+ |ignition harness
STARTER|red/black |+ |ignition harness
IGNITION|black |+ |ignition harness
ACCESSORY|yellow/black |+ |ignition harness
POWER LOCK|brn/gry or red/brn*1 |- |drivers kick panel or alarm
POWER UNLOCK|gray/white *1, *5 |- |drivers kick panel or alarm
see NEGATIVE DOOR LOCKS at www.RELAYHELP.com
PARKING LIGHTS +|gry/blk & gry/red |+ |headlight switch
HEADLIGHTS|yellow or yel/red |+ |headlight switch
DOOR TRIGGER|brn/yel & brn/wht |- |*4
DOME SUPERVISION|use door trigger
TRUNK/HATCH PIN|white/black |- |alarm module *1
HOOD PIN|brown/yellow |- |at hood pin switch
TRNK/HTCH RELEASE|yellow/red |+ |at switch
FCTRY ALARM ARM|arms with lock
FCTRY ALRM DISARM|disarms with unlock
TACHOMETER|green/blue |- |instrument cluster or *2
SPEED SENSE|white/blue |- |instrument cluster or *3
BRAKE WIRE|red/black |+ |at switch
HORN TRIGGER|black/yellow |+ |horn relay
WIPERS|blk/grn(L),blk/pur(H) |+ |steering column
LF WINDOW UP/DN|not recommended
RF WINDOW UP/DN|not recommended
LR WINDOW UP/DN|not recommended
RR WINDOW UP/DN|not recommended
NOTE: This vehicle has an immobilizer system that needs to
be bypassed when adding remote start.
*1 Factory alarm is on the bottom passenger side of the trunk.
*2 Tach is also found at the ECM on the driver side firewall.
*3 VSS is also found at the cruise control module behind the glove box.
*4 Brown/yellow in the drivers kick panel gets the drivers door,
brown/white in the passenger kick panel gets all the other doors.
Use both wires and must diode isolate from each other.
*5 Unlock requires double pulse. See NEGATIVE DOOR LOCK SYSTEM
AT WWW.RELAYHELP.COM
1999-2000 AUDI A4
Autobahnjs
Audi Original "S" Cars
11-21-2006 03:26 PM
the red pill
06-03-2002 08:17 AM
