Is anyone here running the Concert radio system in their A4, but added a subwoofer?
Old 11-17-1999, 09:21 AM
C. Vegas
Guest
Posts: n/a
Default Is anyone here running the Concert radio system in their A4, but added a subwoofer?
1999 A4 1.8TQMS
I would like to know if I can add just an amplifier and then a subwoofer to that amp safely.
Is it O.K. to add an amplifier to the rear wires in the trunk (of course using a level adjuster to convert to RCA's)
Is this signal to be "caught" before or after the rear right amplifier that is surrounding the speaker?
Thanks!
Old 11-17-1999, 10:05 AM
ToddM
Guest
Posts: n/a
Default Re: Is anyone here running the Concert radio system in their A4, but added a subwoofer?
I am not a hundred percent sure, but the car shop I go to said that in the 98-99 Audi A4's there are factory RCA Pre-outs on the back of the stock radio. Hope this helps. Might want to double check me.
ToddM
'00 A41.8TQMS
Old 11-17-1999, 10:26 AM
Rich L.
Guest
Posts: n/a
Default I added a sub to my concert deck.
I got a 12" Infinity, 300W USAccoustics and a sealed box from Crutchfield. It was 3 days of work but it sounds great.
I cut a patch cord and connected it to the pre-amp outputs of the concert deck. First I moved the rear speakers to the front pre-amp then connected the sub to the rear pre-amps. This makes the fader a sub level control.
I shied away from a line level converter on the rear speaker wires. Running the patch cord under the door molding was easy.
I'd be happy to share more detail if you want.
Rich L.
99 1.8TAQMS with BASS
Old 11-17-1999, 07:40 PM
Edward A
Guest
Posts: n/a
Default I have a 180x1 Rockford Fosgate and a 12" Alumapro in a ...
very small enclosure, and it was so boomy, even with the bass at -6, that I had to have a level **** put in. Even after that, I had to turn the woofer to face the back seat and now I can use the bass at 0 and the level **** about halfway. The input for the amp was taken from the back of the stereo, on the high output side (not the low that goes to the rear spkrs, it was too low)
It sounds decent, but nothing out of the ordinary. It helps a lot on the bass, where it definetly needed help.
Old 11-18-1999, 04:21 PM
art
Guest
Posts: n/a
Cannot say I that I did it with a concert series, but added powered bazooka w/ mydelta series. Had no problems at all, well at least until I blew the speaker it in. Waiting to ge off my but an hook up the bandpass sitting in the trunk.
Petros
05-09-2008 12:29 PM
ed007
04-12-2007 06:17 AM
squirrelly333
Audi 100 / A6 (C4 Platform)
04-26-2006 01:27 PM
Ed@mtl
05-02-2003 10:33 AM
bondjamesbond
08-30-2001 07:20 PM
Quick Reply: Is anyone here running the Concert radio system in their A4, but added a subwoofer?
