Audi A4 Heat Problem...NEED HELP ASAP! - AudiWorld Forums
Old 01-16-2008, 07:10 AM   #1
New Member
Default Audi A4 Heat Problem...NEED HELP ASAP!
Hello,
I need some help with my 99 A4 Quattro. Ok, I recently got my coolant flushed many times over again but I am still not getting HOT HOT heat....just warm at times. It seems that the Thermostat is working fine but fluctuates at times. Any idea what this could be? PLEASE HELP!
**The heat is set @ "HI" at all times but does not blow warm at all unless on the freeway....then a little warmer.
soccaplaya6996 is offline   Reply With Quote
Old 01-16-2008, 07:18 AM   #2
Tech Guru
4Driver4's Avatar
Bleed the system where the heater hose meets the heater core.
4Driver4 is offline   Reply With Quote
Old 01-16-2008, 07:20 AM   #3
Default your waterpump could be on its way out... whether that means
a broken impeller blade, or a completely failed pump im not sure.
Also you could throw your thermostat into water and see what temp you have to bring it up to in order to get it to open up. Might be the wrong tstat
Im@wesome~ out! is offline   Reply With Quote
Old 01-16-2008, 07:22 AM   #4
Default Had the same thing after blowing a coolant hose
Just keep the heat up on high and drive up steeeeeep hills. just make sure you stop often tto top off. Took me a bit of time till i got all the air out and the core filled again.
HeartlessNomad12 is offline   Reply With Quote
Old 01-16-2008, 07:29 AM   #5
New Member
Default Re: Had the same thing after blowing a coolant hose
So, all I have to do is drive up a steep hill and stop often? How steep and for how long? Any other alternative?
Old 01-16-2008, 07:43 AM   #6
New Member
Default Re: Bleed the system where the heater hose meets the heater core.
Is this the hose next to the battery?
Old 01-16-2008, 08:09 AM   #7
Tech Guru
4Driver4's Avatar
Yup.
Old 01-16-2008, 12:19 PM   #8
Default I have done the same and cant get hot heat.
What does your temp gauge read? mine reads cold all the time until it sits and idles for a bit. but then it only gets not even half way up.
Anarchy_4play is offline   Reply With Quote
Old 01-19-2008, 09:39 PM   #9
Default Backflush and Burp the heater core
There's writeups on the FAQ
Living Dissed is offline   Reply With Quote
Old 01-24-2008, 03:11 PM   #10
Default Re: Backflush and Burp the heater core
I absolutely agree with the backflush and bleeding the air in the heater core.
Couple of years ago, I had similar issues. The overflow tank looked brownish so there had to be some rust or gunk in the coolant system.
I took the two hoses off at the connection to the heater core near the firewall (between the battery and the brake vacuum booster. Just simply used a garden hose with a spray head (set it to "jet" or "stream") and then flushed the heater core. Be careful as the water may come back to hit you in the face or eyes. Spray water from the outlet hose(closest to the battery; one with a bleeder hole) and saw the rusty gunk come out of the inlet hose (closest to the brake vacuum booster).
Then check the flow by spraying the water from the inlet hose to make sure water was coming out clear. Refill with extra 50/50 coolant/water mixture in the overflow tank and check for correct level.
Have not had problem with heat in the car since.
Aldrich67 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Fault Codes Kerry G Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 06-07-2016 03:55 AM
:: ECS Tuning :: NEW!! B8 S4 ECS Performance Lightweight Flywheel ECS Tuning-Audi S4 (B8 Platform) Discussion 2 03-27-2016 07:49 AM
:: ECS Tuning :: NEW!! B8 S5 3.0T ECS Performance Lightweight Flywheel ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 02-04-2016 09:36 AM
Allroad aux pump relocation stigg Audi allroad 0 09-28-2015 11:37 AM
Question about fuses, cruise control and steering wheel havocgb A6 / S6 (C5 Platform) Discussion 5 09-25-2015 05:50 PM
Tags
1997, 2000, 2001, a4, audi, bleed, burp, burping, coolant, heat, heating, problem, problems, s4, tt
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
