Need Help: check engine light: small evap leak (intermittant) --- large evap leak
Old 12-10-2001, 02:33 PM
Member
Bimmer Love's Avatar
Default Need Help: check engine light: small evap leak (intermittant) --- large evap leak
every time I clear these codes, they come back
within minutes. I already tightened the gas
cap, and the oil cap. What else could be
causing this code?
Is there any way I can diagnose the problem using
a VAG?
Old 12-10-2001, 02:40 PM
Senior Member
phred's Avatar
Default I'm having similar problem
When they cleared my codes in the service drive with the VAGCOM, it gave suggested leak locations. I guess it's usually the gas cap, but it can also be hoses under the hood.
Old 12-10-2001, 02:43 PM
Member
Default well, the vagcom didn't give me any suggested leak locations.
I'm guessing you meant the dealer's VW tool.
I gotta find a way to snag me one of those
suckers.
Old 12-10-2001, 03:06 PM
Member
Yippers®'s Avatar
Default did you look at the error code in the Bentley's? I'm at work and Bentley's is at home but if no one
else shows I will take a look see when I get home.
Old 12-10-2001, 03:09 PM
Member
I'm poor. I have no bentley manual. I'll see if I can get the screen shots up soon.
Old 12-10-2001, 03:13 PM
Member
Yippers®'s Avatar
k .. I will look at Bentley's when I get home .. in case no one w/ replies.
Old 12-10-2001, 06:21 PM
Member
Yippers®'s Avatar
Default Bentley's DTC description was none to helpful .. what you got from the vag about covered but
<center><img src="http://pictureposter.audiworld.com/19399/evapleak.jpg"></center><p>
Old 12-10-2001, 07:21 PM
Member
Yippers®'s Avatar
Default Here's a pic of the evap system .. for connection checking
<center><img src="http://pictureposter.audiworld.com/19399/evap_circuit.jpg"></center><p>
Old 12-10-2001, 08:58 PM
Member
Default I'm thinking I'll let the dealer check this one out. unless I get impatient.
my next service appointment isn't until Jan 3rd.
ps: thanks for all the help!
Old 12-10-2001, 09:06 PM
Member
Yippers®'s Avatar
NP ... lots of connection in that system. Take till Jan 3 rd to check em all
Quick Reply: Need Help: check engine light: small evap leak (intermittant) --- large evap leak
