Audi says my turbo doesn't work.
Old 12-10-2001, 08:50 PM
TommyC's Avatar
Default Audi says my turbo doesn't work.
I took my car to my local Audi dealership because I thought it was kinda slow. Turns out my turbo isn't working. I have some questions:
Could it be my BPV not functioning?
How can I test it without buying a boost gauge?
Should I put in a KO4?
What do you guys think I should do?
Old 12-10-2001, 08:57 PM
WYSIWYG's Avatar
Default broken turbo isnt 'kinda slow' - you'll know for sure
definitely something else than the turbo itself
Old 12-10-2001, 09:04 PM
TommyC's Avatar
Default Re: broken turbo isnt 'kinda slow' - you'll know for sure
I know that something is wrong. MY CAR IS SLOW.
Old 12-10-2001, 09:08 PM
WYSIWYG's Avatar
well if its the turbo, might as well go for atleast the k04 + FPR (and/or injectors)
Old 12-10-2001, 09:11 PM
TommyC's Avatar
Default Could the BPV be the problem.
I really don't know what part the BPV plays in the system, but could it cause the majority of the boost to be lost?
Old 12-10-2001, 09:15 PM
Member
Yippers®'s Avatar
Yes .. if the BPV diaphram is torn you would lose boost big time.
Old 12-10-2001, 09:17 PM
TommyC's Avatar
Default Re: Yes .. if the BPV diaphram is torn you would lose boost big time.
How can I check if it is torn?
Old 12-10-2001, 09:21 PM
Member
Yippers®'s Avatar
Default Pull the hose on the front edge of the intake manifold and put a vacumm on it. If you can pull a vac
it is likely alright. If it won't the diaphram is likely gone. You want to have a fresh clamp as the OEM WILL get dicked up pulling it off.
Old 12-10-2001, 09:24 PM
Member
Yippers®'s Avatar
Default Also .. they will often make a nasty sound when the pressurized air goes thru them .. burst hose can
also be at issue. Just make sure the dealer checks and eliminates the simple items BEFORE they try to sell you a turbo.
QuattroDrive
08-23-2005 06:36 PM
Chris(DE)
04-11-2005 03:37 PM
Adam Mowafy
18
12-02-2003 05:04 PM
A4Turbo22
08-21-2003 10:48 AM
ZERO44
04-14-2002 10:41 PM
Quick Reply: Audi says my turbo doesn't work.
