Automatic Transmission need help!
Old 09-01-2015, 01:32 AM
jjyerro's Avatar
Default Automatic Transmission need help!
I have automatic transmission. Whenever the car changed gear at low speed, I felt a bump when changing gear.
any suggestions? the last time I changed the transmission fluid is last july 2013.
Old 09-01-2015, 08:16 AM
jjyerro's Avatar
I need help please!
Old 11-20-2015, 09:49 AM
paully's Avatar
Default I have the same issue, 2002 s4, intermittent and slight
It does this more when its cold but shifting isn't quite right. There is a slight pause and then it kicks into gear, seems to be when I am coasting and it is trying to down or upshift. Did you ever figure this out?
Old 11-22-2015, 06:31 AM
jjyerro's Avatar
no, I just lost my reverse last week. -___-
Old 11-24-2015, 10:33 AM
Nemick's Avatar
Unfortunately you'll need a new (used/rebuilt) transmission, most likely.
Old 11-24-2015, 12:11 PM
raj99's Avatar
+1 on this...your tranny is toast.
This is an idea of rebuilding...
Old 11-27-2015, 09:11 AM
jjyerro's Avatar
based on what I read from another forum, they said that sometimes the problem is the multi-function switch. Is it possible? I read that when they put the gear on reverse it only rev and the solution for their problem is to replace the MFS
Old 11-29-2015, 06:32 AM
jjyerro's Avatar
is it possible? I need answer please
Old 12-01-2015, 11:42 AM
Prospeeder's Avatar
No, you could unplug the electrical connector from the trans and it would have 4th gear and reverse.
Old 12-14-2015, 12:55 PM
bydand's Avatar
Default Check for codes
Yes its possible it is the MFS, I would rather you had the car scanned and read the codes, then take it from there.
Use.
Ross-Tech: VCDS
Ross-Tech: VCDS
2002: The first aftermarket tool which supports 7-Digit SKC codes and is able to access modules requiring proprietary VAG modes on the KWP-2000 protocol ...
A stab in the dark, which is cheap.
If you remove the MFS plug from the socket by the transmission, and see if it is corroded etc. clean it up and see if it improves things.
Quick Reply: Automatic Transmission need help!
