Battery died, Engine won't start - AudiWorld Forums
Old 01-09-2011, 09:25 AM   #1
Default Battery died, Engine won't start
1999 A4 1.8T - battery died a couple of nights ago (girlfriend left dome light on), her brother came over while i was at work and tried to jump it . now she won't start. All fuses are good, fuel pump works, checking coil packs now. could jumping the car fry the coil packs or ICM? is there any way to check ICM without taking it to a mechanic? ordered VAG to USB but will not be here for a week. any help would be GREATLY appreciated as this is our only vehicle. i'm an NA guy so this EFI is new ground for me.
cuezer is offline   Reply With Quote
Old 01-09-2011, 11:25 AM   #2
i would check on Generator/ Alternator. That happened to someone else and i came and tried helping and it wasnt the battery. If the battery isnt old it just died because the Alternator broke and it took all the power from battery instead.
iloveyulya1 is offline   Reply With Quote
Old 01-09-2011, 12:23 PM   #3
Default update:
i unplugged the coil pack connections and tested... icm is good, i tested all of the coil packs... coil packs good, did compression check... compression seems ok on 3 cylinders, #2 however seems to take a while to reach correct PSI. i finally got the car to run and idle, however, when revving up to around 3k and letting of accelerator fast, engine stumbles, tries to die, and burns oil for a few seconds. my guess is that i am getting blow-by into the #2 cylinder. this still doesn't really explain to me why the car wouldn't even start for 2 days and then finally start today after only testing everything. any ideas???
Old 01-09-2011, 03:17 PM   #4
have you checked on gas pump and filter and eletricals. seems to me you got a cylinder issue. I havent had a problem like this before. But it could be something else.. what gas were you using? 1.8t requires premium
Old 01-09-2011, 03:44 PM   #5
Quote:
listen, i don't mean to be rude and do appreciate your concern with my issue and willingness to help, but it appears as though this issue is way out of your league of expertise. twice now you have given responses that show you clearly have not read or understood my posts/updates. again, i do appreciate your concern but am looking for some thoughts or ideas from a seasoned audi man/woman.
Old 01-09-2011, 04:09 PM   #6
mksu19's Avatar
Hi iloveyulya1, is your real name Adam by any chance?
mksu19 is offline   Reply With Quote
Old 01-09-2011, 05:24 PM   #7
Mechanical problem just because of a dead battery doesn't make any sense. The problem with cylinder #2 might have been there before, but you just found it now while looking for the no start problem.
Did you do a throttle body adaption? It won't run right unless this is done after a dead battery. Beyond that you will need to further investigate the cylinder #2 issue and VAG com it to see what is going on with electrical things that could have been messed up by the dead battery.
5v/cyl is offline   Reply With Quote
Old 01-09-2011, 06:17 PM   #8
AudiWorld Expert
Reggie's Avatar
There is also the possibility that someone jumped the car backwards initially.This will fry a lot of things.http://forums.quattroworld.com/rocky...gs/21697.phtml
Reggie is offline   Reply With Quote
Old 01-10-2011, 08:48 PM   #9
Quote:
My name is mike
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: NEW!! B8 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B8 Platform) Discussion 14 12-23-2016 04:46 AM
Why I hate NJ's numbnuts rules... carl viking A8 / S8 (D3 Platform) Discussion 34 08-22-2016 08:44 PM
:: ECS Tuning :: NEW!! B7 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-01-2015 10:16 AM
:: ECS Tuning :: NEW!! B8 A5 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-01-2015 09:27 AM
Audi C4 2.6 Could not start aron56 Audi 100 / A6 (C4 Platform) 0 09-01-2015 01:39 AM
Tags
1996, 1999, a4, a6, audi, battery, body, dead, gas, jumped, run, start, throttle, widget, wont, work
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
