So I installed my vvme HID kit tonight...
thought I'd post how I ended up strapping the ballast down.
Found some stainless steel straping tape that I bended to form around the ballast. Drilled holes in the tape and screwed it into the OEM holes.
Then I rounded off the edges to be sure I wouldn't cut my hands on it.
<img src="http://pictureposter.audiworld.com/70024/hid_insta_001.jpg">
I'm still debating whether or not I should do two for each ballast but it seems the stay in place for now.
pretty clever....here's mine when I installed mine several yrs back.
<center><img src="http://pictureposter.audiworld.com/38898/xenons.jpg"></center><p>I dremeled the boxed area to make room for the large ballast....used double-stick tape + Ziptied it. I've taken the headlights out on numerous occasions throughout the yrs, and its still holding up.
That should work fine.
I used 3M exterior mounting tape #4011, and lots of GE silicone to seal everything up.
<img src="http://pictureposter.audiworld.com/71840/02-03-07_021s.jpg">
<img src="http://content.etilize.com/500/11965194.jpg">
What housings are you guys using? Halogen Projector or HID Projector?
I got my kit but still need to order housings.
Currently I have the old 2-piece housings with the integrated fogs (non-projector).
My guess Home Depot
<center><img src="http://pictureposter.audiworld.com/70024/hid_insta_002.jpg"></center><p>Found some in the basement but here's what it looks like.
It's fairly thin but strong and easy to work with.
