Cylinder 3 Random Misfire Help
Old 12-12-2013, 05:42 PM
jetice's Avatar
Default Cylinder 3 Random Misfire Help
I know this is a common topic, but I have tried most of everything I have found to no avail. So far i have tried:
New spark plugs
New coils
Moving injectors to see if it moved with them
New ICM
It seems to be more prevalent at lower RPMs. I have a feeling that it might be the wiring harness. This is a pretty high-mileage car, so is there anything that tends to go bad with lots of miles? What are you guys' thoughts? Thanks for the help!
Old 12-12-2013, 08:56 PM
JohnelP's Avatar
Do you get only the P03003 code?
Nothing else?
Misfires are hard(er) to troubleshoot - eg. I had to clean the RPM sensor for random misfires at cold start (but for all cyls though ....)
Where did you get the ICM from?
Old 12-21-2013, 06:14 PM
Stephen Todd Tackett's Avatar
Nightmare is all I can say. I have a Cylinder 3 misfire. Replaced all spark plugs, all coils still rattling and idling well below 1 - almost stopping. So a mechanic discovered a hole in the intake manifold.
Lets see if this is the cause of the misfire. Otherwise it could be a cylinder gone back. and thats over 2 thousand dollars.
The history is that my check engine light was on for a long time - 2 thousand miles or so - Why did I ignore it? There are numerous electrical problems. I thought is was that.
I guess I will find out Monday.
Old 12-21-2013, 07:24 PM
tr3ndsetr's Avatar
I drove 20K with check engine light, on my old A4 (which I still have). Initially it was just O2 sensor, but then one day I was driving and the car engine just cut out. MY cylinder heads needed to be replaced. My German specialist mechanic found a unit on Ebay for $350 and installed for $650. So, you might want to check Ebay for a used component.
beachcomber
14
07-26-2021 05:08 AM
levansula
24
01-26-2021 04:02 AM
amdreamer1
05-08-2019 09:01 AM
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
smiladon
10-01-2015 01:31 AM
Quick Reply: Cylinder 3 Random Misfire Help
