Can anyone help me rid my car of a sunroof?
Old 10-24-2005, 12:30 PM
Junior Member
tkarwin's Avatar
Default Can anyone help me rid my car of a sunroof?
I would like to have it look very clean and stock, and I for sure don't want to have to worry about the "sunroof" leaking. Did our cars ever come without sunroofs? Would it be possible just to find the roof insert from a car without a sunroof and sway them? It would be great if I could lose the weight of the sunroof. Any help would be great, thanks.
P.S. Has this mod ever been done before? How much weight can I expect to save by losing the sunroof?
Old 10-24-2005, 12:35 PM
FAQ Author
BSK auf Arbeit's Avatar
Default aehm... cars with sunroof have the whole CUT into their cars there are no kits
weight saving? maybe 40lbs or so if at all.. more a hassle than worth the work. one of the induktion cars had the sunroof removed and a custom cf into its place.. custom made and custom $$$$ big time as well.
Member
Silver Streakin''s Avatar
Default sure, talk to a body shop.
weld in sheet metal, sand, and paint it.
get the interior liner for an A4 without a sunroof, if having the slider for it bugs you.
Old 10-24-2005, 12:36 PM
Junior Member
tkarwin's Avatar
Default Would I be able to find a whole roof section from a car that didn't have a sunroof?
I could put that in place of my room section. Yes/No?
Old 10-24-2005, 12:37 PM
Member
not without a lot more work than just welding in a new piece for the hole that was cut.
Old 10-24-2005, 12:38 PM
Im@wesome~ out!'s Avatar
no... stick to silver streakin... sheet metal.. weld.. paint .. done
Old 10-24-2005, 12:40 PM
Junior Member
tkarwin's Avatar
Sounds good, It would be nice to save 40 lbs or so from the very top of the car.
Old 10-24-2005, 12:44 PM
AudiWorld Expert
S4iowa's Avatar
Default Keep in mind that you will devalue the car.
And you will have to fix the headliner inside and lots of things to fix to make it look like it never existed. Whats wrong with just leaving it shut?
Old 10-24-2005, 12:47 PM
FAQ Author
Default if you have a shop and enough time and work like a pro maybe
ive seen that done in germany once where they cut 2 cars apart with nearly identical chassis numbers. one of the cars had some roof damage and they cut the roof off and welded the one from the other car back in but it was more of a hassle than worth anything
AudiWorld Expert
de (-eeez_nutz)'s Avatar
Default I just had my whole roof sheet metal replaced as well as...
...the rear pass quarter panel along with the area to the outside of the rain gutter that's one piece with that quarter panel, and the polished Al window trim (30v V6).
The total bill came to $1700 and some change, at a reputable local body shop, that's usually on the higher end of the price spectrum. I'd guess that to replace just the roof sheet metal shouldn't be more then $1000. Then there's the new headliner price to factor in, as well as little bits and pieces (new overhead console with no sunroof switch, etc...)
FYI, for your reference.
Quick Reply: Can anyone help me rid my car of a sunroof?
