Rear differential questions
Old 03-20-2011, 03:13 PM
mtroxel's Avatar
Default Rear differential questions
99.5 A4 Q with 2.8. I have a bad seal on the front of my rear diff....right where the drive shaft attaches. My Bentley doesn't mention a rear differential. It looks like there is a case I could just take right off the differential.
Does that case share the same fluid as the entire diff?
I believe there's some screwy tool to loosen the fill plug. Is it this?
Old 03-20-2011, 04:13 PM
Tech Guru
4Driver4's Avatar
I'm guessing you mean the center diff? Rear diff is not connected to the rear of the trans.
Try searching for "tailshaft seal"
Old 03-20-2011, 05:17 PM
mtroxel's Avatar
No I mean rear diff. On the front of the rear diff is a case that's bolted on. My bad seal is at the front of that case, right where the drive shaft connects.
Old 03-20-2011, 07:34 PM
HBAudi's Avatar
Originally Posted by mtroxel
99.5 A4 Q with 2.8...Does that case share the same fluid as the entire diff?
The rear differential uses GL-4 or GL-5 specification synthetic lubricant and requires about 1.8 litres on a refill. The fill and drain plugs on the rear differential assembly should be Allen type fasteners.
The 'tamper-proof' drain on the gearbox is an XZN-type 16mm socket similar to the one shown in your link.
The procedure for replacing the differential front seal is in the Bentley shop manual.
Old 03-21-2011, 05:01 AM
mtroxel's Avatar
I found a DIY for changing fluid in the rear diff. Saw the two allen bolt plugs. I must have been thinking about the gearbox plug.
Yea but it's odd that Bentley never mentions the rear diff. I think I found a technial bulletin on it....that's it. Weird.
Old 03-21-2011, 12:13 PM
HBAudi's Avatar
...Yea but it's odd that Bentley never mentions the rear diff. I think I found a technial bulletin on it....that's it. Weird.
The complete procedure is in section 39 Final drive, Differential.
Old 03-21-2011, 12:33 PM
mtroxel's Avatar
Weird. I was looking under "5 Spd. Manual Transmission 01A All Wheel Drive". Group 39 has no rear differential. I gotta go to group 39 under "6-Spd Manual Transmission 01E". That group shows the final Diff.
My Bentley is on my hard drive...don't know if that makes a difference....
Old 03-21-2011, 12:56 PM
HBAudi's Avatar
...My Bentley is on my hard drive...don't know if that makes a difference....
Depending on the version you have; you can go to www.bentleypublishers.com and download the latest version (3.1.0) of eBahn. In that version, the final drive differential unit is listed under both 5-speed and 6-speed manual transmission.
Old 03-21-2011, 04:35 PM
mtroxel's Avatar
Nope. Look at this. I don't care now, I see where to find it.
Old 03-21-2011, 07:41 PM
HBAudi's Avatar
Glad you found it.
rakta *chchchanges
12-24-2008 06:13 PM
a-4cefed
12-06-2006 10:02 AM
Mr. Malcontent
Audi 100 / A6 (C4 Platform)
10-30-2005 12:31 PM
A4Twin
05-12-2004 10:26 AM
markbradford
04-01-2003 02:51 PM
Quick Reply: Rear differential questions
