CEL is on today. Code:P0153 Oxygen Sensor Bank2 Sensor1 slow response
Old 06-06-2008, 03:07 PM
New Member
Shan H's Avatar
Default CEL is on today. Code:P0153 Oxygen Sensor Bank2 Sensor1 slow response
Just did timing belt job. The car is running fine. After 50 miles of driving, the cel is on with P0153. It is the front driver side O2 sensor. Before I purchased this car, two O2 sensors were replaced at 120K. Those two sensors(I remembered) are located on the driver side as well. Now the car has 137K. So what kind of problem do I have here? Is it related to timing belt replacement? Also, I added some engine oil after timing belt job. It is over the MAX mark now. Will that cause the O2 to fail? Thanks!
Old 06-06-2008, 03:21 PM
Tech Guru
4Driver4's Avatar
Default What kind of sensors were used? OEM or "universal".
If OEM, reset the light and see if it comes back, if "universal", replace with OEM.
Not related to t-belt service.
Old 06-06-2008, 06:09 PM
New Member
FRAULEIN's Avatar
Default ummm how much overfil on the oil? Why did you even drive the car if it was way over?
That blow by can hurt the cats as far as I think I know so I bet it ain't great for anything else along the line? Anyone?
Old 06-07-2008, 10:33 PM
cbkenison's Avatar
Default I would attribute your oxygen sensor failure to both
Universal
and overfill
BiZzAro ThAi
9
11-16-2005 07:41 AM
urluzn2
04-17-2005 01:27 AM
a_o_smith
03-13-2005 06:29 PM
TurboEnvy52
05-23-2003 10:06 AM
Quick Reply: CEL is on today. Code:P0153 Oxygen Sensor Bank2 Sensor1 slow response
