Check Engine Light/ Engine Shaking
Old 12-08-2010, 11:45 AM
  #11
AudiWorld Expert
Reggie's Avatar
Originally Posted by Telsdon
I wanted to give ya'll an update on what happened;
Replaced that for $450. Also got an oil change (oil light will not go off for some reason though - any ideas?) and a few other things that popped up ($$$).
All things considered, she's done pretty well for her age! I'm so happy with my car! LOTS of LOVE for Audi.
Is this the low pressure light or the change the oil indicator or low oil amount? If it is the low oil pressure light Did the oil come on before this or just at the service place now.
If you are going keep the car it is worth it to get a VAG-COM and Bentley manual. Will save you money in the long run to do some of your own maintenance
Old 10-06-2015, 12:10 PM
  #12
SteelyD's Avatar
I recently had a similar issue with my 2006 Audi A4 2.0T Quattro. When trying to accelerate in high rev situations (~3k revs/min) up a hill or passing someone on the freeway, I would see a drop on the tachometer, the engine would shake, and I wouldn't the the power I expected. The first time the check engine light flashed, but went away. The next time it stayed on. I bought a Autel MaxiScan MS300 DTC reader ($17 on amazon), read P304 (misfire on the 4th cylinder), replaced the ignition coil (less than 5 minute job after viewing a youtube video), and no longer have the issue.
My question is how would you know if the issue was the spark plug or the ignition coil? Replace each one at a time and retest?
Also, do ignition coils need to be changed at regular intervals just like spark plugs? I have no idea when the ignition coils were last changed, should I just change out the other 3 as well?
Thanks!
erionracing
07-11-2018 02:43 PM
pablito
New Member Welcome Area
01-01-2018 04:54 PM
victor army
05-13-2006 04:02 PM
vaila4
08-01-2002 08:05 PM
Jim Ot
10-08-2000 02:56 PM
Quick Reply: Check Engine Light/ Engine Shaking
